Hang on startup
LUFTY
LUFTY
Posts: 15, Visits: 65
Hi There
I am getting problems with starting Skyplan 2.0 under Windows 7 32 bit.
It hangs on either the navigation warning or more often when the route start/to window appears.
If you wait for about a minute or two it tends to recover.
Without a working Internet connection you tend to get a GPF.
I have grabbed the following error dump when it crashed on the navigation warning :-
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: SkyDemon.exe
Application Version: 0.0.0.0
Application Timestamp: 00000026
Hang Signature: d38a
Hang Type: 256
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Additional Hang Signature 1: d38adcbb8c649a00aa1a9e99eb827f86
Additional Hang Signature 2: 28d7
Additional Hang Signature 3: 28d7dbf8bc3f29623015fe604932bf59
Additional Hang Signature 4: d38a
Additional Hang Signature 5: d38adcbb8c649a00aa1a9e99eb827f86
Additional Hang Signature 6: 28d7
Additional Hang Signature 7: 28d7dbf8bc3f29623015fe604932bf59
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Lufty
Hello Lufty, what do you mean by "navigation warning" in this context?
LUFTY
LUFTY
Hi Tim
The warning message "The software is intended an aid to flight planning ..."
Many thanks
Lufty
Oh, I see. If facing something like this I would be tempted to uninstall SkyDemon, remove all charts and terrain data, then reinstall it. Beyond that, it's likely to be something machine-specific as it doesn't appear to be happening anywhere else.
LUFTY
LUFTY
Hi Tim
I have installed SkyDemon on another Windows 7 laptop (this time 64 bit rather than 32 bit) and the "New Route" window freezes for several seconds (you get the hour glass) but you can move the window around.
You then get a not responding within the window title bar.
Several seconds later everything is back to normal and working fine.
It would seem like a similar problem although it does not GPF.
Lufty
Did you try what I suggested?
