Hide airspace class "E" possible?
Bumelbee
Bumelbee
Posts: 23, Visits: 201
Hi, I was wondering, if it is possible to hide class "E" in order to declutter the map a bit more. Echo is controlled airspace, though it does not need a clearance, any warnings about it or even it showing on the map is for me rather annoying.
It would be a nice feature to not only choose between controlled and on the uncontrolled airspace showing but in addition to deactivate Echo. Maybe this feature already and I just don't find it.
Best regards
Posts: 626, Visits: 15K
Bumelbee - 3/4/2017 7:42:08 PM
Hi, I was wondering, if it is possible to hide class "E" in order to declutter the map a bit more. Echo is controlled airspace, though it does not need a clearance, any warnings about it or even it showing on the map is for me rather annoying. It would be a nice feature to not only choose between controlled and on the uncontrolled airspace showing but in addition to deactivate Echo. Maybe this feature already and I just don't find it. Best regards
You can turn off Class E airspace warnings in Settings > Navigation Options but as far as I'm aware it is not possible to stop it appearing on the chart
Samsung Galaxy Tab A8 – Android 11.0 & SD 4.1.1.0
Huawei P30 – Android 11.0 & SD 4.1.1.0
6036, SD 4.0.2.0
Posts: 8.1K, Visits: 9.4K
An interesting idea, we will wait to see if anybody else wants this.
tschnell
tschnell
Posts: 25, Visits: 149
+ 1 from my side.
Easy Cruising
Easy Cruising
Posts: 50, Visits: 39
+1
alexis.hellen@gmail.com
Posts: 56, Visits: 753
I second that idea, because:
-‌ I find it annoying to get a message every time I climb into E airspace, this is information i really don't need, and would love to be able to choose to disable or enable
-‌ In the debriefing pack, I often get half a page of "entering E airspace" and "leaving E airspace" (or something similar), which is of no interest to me
Thanks‌‌ a lot for a great product
Alexis‌
Chris_LSZO
Chris_LSZO
Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)Too Much Forum (8.3K reputation)
Posts: 107, Visits: 149
+1
We have added an option to turn off just class E airspace on the map, in the forthcoming version of SkyDemon.
Please note that you can already disable warnings/alerts about entering class E.‌‌
berndalfred
b
Posts: 34, Visits: 1.7K
Tim Dawson - 4/20/2017 9:24:19 AM
+1
Bumelbee
Bumelbee
Perfect and thank you very much! That really shows, the SkyDemon community works an is alive.
I am looking forward to the upcoming version where it is possible to disable Echo. Perhaps right now I am planning different routes through the French airspace and this will be a very useful tool, because the airspace is already clustered with Charlie and restricted airspace so putting away echo will make it a bit easier.
Thanks again and happy landings.
Greetings from www.edmy.de
