Can't save routes on Android tablet
rjmusto
r
Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)Too Much Forum (739 reputation)
Posts: 6, Visits: 2
Android: 4.2.2
SD : 3.6.3.28529
New user here, so may well have missed something obvious.
I can create routes and save them to cloud on the PC and then open them on the tablet. No problem.  But I am unable to save them locally on the tablet. I can open the Save As dialogue and give it a name, but the instructions then say to click Done. But I don't have a 'Done'. No sign of it - and anything I do click closes the dialogue without saving the route. (Clicking the Return button, bottom right, doesn't do anything.)
Any help much appreciated.
Posts: 626, Visits: 15K
rjmusto - 8/29/2016 7:48:20 PM
Android: 4.2.2
SD : 3.6.3.28529
In the Save As dialogue box, having entered a name for your route file, hit return on your keyboard, and the Save As dialogue box disappears. If you then tap on Route > Open and you should see your route listed. To reload it, just tap it.
Samsung Galaxy Tab A8 – Android 11.0 & SD 4.0.2.0
Huawei P30 – Android 11.0 & SD 4.0.2.0
5917, SD 4.0.2.0
rjmusto
r
Posts: 6, Visits: 2
Sky Painter - 8/30/2016 6:52:51 AM
Android: 4.2.2
SD : 3.6.3.28529
Hi Mike,
Thanks for the reply.
This doesn't work for me. Hitting return just zooms the map in and the SaveAs dialogue box stays on the screen. Taping elsewhere on the map does make it disappear, but no route is then saved.
Ralph
rjmusto - 8/30/2016 4:36:57 PM
Android: 4.2.2
SD : 3.6.3.28529
Hi Mike,
Ralph
Hi Ralph
In that case, I would try uninstalling SD and then reinstall and see if that sorts things out. Which particular make of tablet are you using? Do you have another Android device, such as a phone, that you try it out on?
5917, SD 4.0.2.0
George Reid
George Reid
Posts: 113, Visits: 1.5K
Sky Painter - 8/31/2016 6:36:44 AM
Android: 4.2.2
SD : 3.6.3.28529
Hi Mike,
Ralph
Hi Ralph
On android devices, after typing a name for the route to be saved you need to tap the green checkmark symbol Image result for checkmark symbolon the keypad.
George E A Reid
GEAR - 8/31/2016 6:48:09 AM
Android: 4.2.2
SD : 3.6.3.28529
Hi Mike,
Ralph
Hi Ralph
... which is the equivalent of the return key. Some devices don't display a green check mark, only the conventional return key. For instance, my Nexus displays the green check mark, but my HTC phone only displays the conventional return key. I didn't mention the green check mark in my reply to Ralph, because I noted that in his original post, the embedded image of his device's screen was only displaying the conventional return key and not the green check mark. To have mentioned the green check mark in this context may have confused things somewhat.
5917, SD 4.0.2.0
George Reid
George Reid
Good point Mike.
George E A Reid
rjmusto
r
Posts: 6, Visits: 2
Hi Guys,
I did try uninstalling SD and re-installing. Didn't help.
The tablet is a Prestigio Multipad 4 that I bought in Maplin.
As you can see in the original photo, I have one route saved locally (no idea now how it got there) and I can do the SaveAs thing and click on that and it saves the route under that name. But only being able to save one route at any time is a bit limiting obviously - plus I can't change the name....
I don't have another Android device here - just my wife's iPad, and, yes it all works fine on that.
Ralph
rjmusto
r
Posts: 6, Visits: 2
Update:
Went through the whole uninstall thing again, this time including  a reboot in between. No change.
But - I have just discovered that I can save locally, but only in landscape: in landscape I get a text enter screen with a DONE button when clicking in the name box.  In portrait this doesn't happen and I have this 'can't save route' issue.
So an easy workaround  (but maybe something that is fixable in an update?).
Ralph
rjmusto - 9/1/2016 6:27:54 PM
Update:
Ralph
It sounds to me like a device specific issue.
5917, SD 4.0.2.0
