SkyDemon Flight Planning
Can't save routes on Android tablet
Prev
1
2
Jump To Page
posted 9/2/2016 7:44:33 AM
Visits: 2.5K
x
Sky Painter - 9/1/2016 7:52:14 PM
x
rjmusto - 9/1/2016 6:27:54 PM
Update:
Went through the whole uninstall thing again, this time including a reboot in between. No change.
But - I have just discovered that I can save locally, but only in landscape: in landscape I get a text enter screen with a DONE button when clicking in the name box. In portrait this doesn't happen and I have this 'can't save route' issue.
So an easy workaround (but maybe something that is fixable in an update?).
Ralph
It sounds to me like a device specific issue.
Hi Ralph,
So the "keyboard" changes format between portrait and landscape modes? If so then, as previously mentioned, this is most likely a device specific issue. Perhaps there is a setting within your tablet which may change the depiction/format of the keyboard?
Tony
psuter
psuter
posted 9/2/2016 5:48:22 PM
Visits: 31
x
Update:
Ralph
On an android device, you have a choice of installing different keyboard apps. maybe the one that came with your device was not programmed correctly and uses something funny for the return key in portrait mode. you can install other keyboard apps from the play store. try another app and see if that helps if rotating the tablet is not acceptable as a solution to this problem.
try the "google keyboard" from google, if you see that in your play store. that should be the "original" keyboard google is using on their devices (at least that's whats installed on my nexus)
Prev
1
2
Jump To Page
