mainhatter
Visits: 0
Hi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars
mainhatter
Visits: 0
+xHi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/ Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars I run MacOS Sierra in Version 10.12.6 ...
rikur
Visits: 632
+xHi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/ Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars Have you got a $HOME/Documents/SkyDemon/ folder? If so, is it empty? I've seen it hang at that point when it's unable to create this for some reason.
mainhatter
Visits: 0
+x+xHi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/ Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars Have you got a $HOME/Documents/SkyDemon/ folder? If so, is it empty? I've seen it hang at that point when it's unable to create this for some reason. That folder exist and contains several folders and the license.skdl. As folders there are Aircraft, Charts, Custom Data, Logs and Routes - all Folders are empty...
rikur
Visits: 632
+x+x+xHi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/ Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars Have you got a $HOME/Documents/SkyDemon/ folder? If so, is it empty? I've seen it hang at that point when it's unable to create this for some reason. That folder exist and contains several folders and the license.skdl. As folders there are Aircraft, Charts, Custom Data, Logs and Routes - all Folders are empty... Grasping at straws, try cleaning things up, from a terminal prompt: rm -rf $HOME/Documents/SkyDemon rm -rf "$HOME/Library/Application Support/Divelements Limited/"
mainhatter
Visits: 0
+x+x+x+xHi again, and sorry for the late reply. I don't come here everyday. Thank you for your reply rikur. I've booted the my system several times before I referred to this forum, though it didn't help. I just tried to find the folder described above, but couldn't find it on my system...? $HOME/Library/Application Support/ Divelements Limited/SkyDemon Plan .. the bold folders do not exist in my case. At present, my startup freezes directly after the message, that I need to download any charts first. I see the checkboxes, but cannot select any. Any more ideas? Regards Lars Have you got a $HOME/Documents/SkyDemon/ folder? If so, is it empty? I've seen it hang at that point when it's unable to create this for some reason. That folder exist and contains several folders and the license.skdl. As folders there are Aircraft, Charts, Custom Data, Logs and Routes - all Folders are empty... Grasping at straws, try cleaning things up, from a terminal prompt: rm -rf $HOME/Documents/SkyDemon rm -rf "$HOME/Library/Application Support/Divelements Limited/" That worked...! Don't understand why, though, but anyway. Thanks a lot for your support!!!
rikur
Visits: 632
+xRequest, can we have some place where the latest download link is prominently placed? I changed to a new computer and was trying to find out where to find the last version as I abandoned Parallels to run the Win version of Plan. THX! The link in the very first post on this thread is generally kept up to date with the latest version of the wrapper ...... and Skydemon will auto-update itself within the wrapper to the latest version of Skydemon ..... if in doubt, use the link in the first post of this thread (which is itself 'stickied' to the top of the forum).
Cessnaoui
Visits: 0
Hello, Anyone already tried Skydemon for Mac on OS X High Sierra ? Is it working ? THX!
rikur
Visits: 632
+xHello, Anyone already tried Skydemon for Mac on OS X High Sierra ? Is it working ? THX! Not risked it yet .... I'll let you go first ;-)
Cessnaoui
Visits: 0
+x+xHello, Anyone already tried Skydemon for Mac on OS X High Sierra ? Is it working ? THX! Not risked it yet .... I'll let you go first ;-) I will do the step tonight ... wait & see.
