Scratchpad - Swipe activation / screen timeout
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
I recently discovered two items regarding the scratchpad.
- swipe activation only works when Virtual Radar is active, hence no moving plane no scratchpad swipe activation.
- leaving scratchpad on activates screen timeout
maybe somebody can give it a try whether it´s only my device.
thx
-mike
Mike@EDTG (8/13/2015)
- leaving scratchpad on activates screen timeout.
Quote from SD Manual:-
Scratchpad
This is a simple canvas which you can write or draw on with your finger to jot down quick notes. The contents of the canvas are retained until the app is closed and restarted or until you manually clear it.
In the iOS and Android apps the scratchpad can be accessed easily from the main menu when you're in Go Flying mode and contains multiple pages that can be scrolled through using the 'Next Page' buttons.
Tip: To quickly access the scratchpad swipe your finger from right to left across the Virtual Radar at the bottom of the screen.
Clearly, the Scratchpad is designed to be used in flight only so, ipso facto, you have to be in flying/simulation mode for it to be available. I can confirm that leaving the Scratchpad open invokes screen timeout on my device.
Edit: You might also want to check the following threads:-
http://forums.skydemon.aero/Topic15751.aspx#bm15782
http://forums.skydemon.aero/Topic15859.aspx#bm15873
6332, SD 4.1.2
Edited 8/13/2015 10:42:51 AM by Sky Painter
Posts: 8.2K, Visits: 9.5K
Why shouldn't the screen time out when you've got the scratchpad open, if you don't use it for a time?
Mike@EDTG
Mike@EDTG
Ï
Tim Dawson (8/13/2015)
...so it's a feature, not a bug. ;-))))
-mike
I totally agree. I don't see it as a problem. I was just confirming for Mike@EDTG that it is not his device that is at fault.
6332, SD 4.1.2
