Scratch Pad
kenrcatt
kenrcatt
Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)Too Much Forum (509 reputation)
Posts: 4, Visits: 9
Scratch Pad
Could scratch pad hold pages in memory after the app has been shutdown?
Reason
If SkyDemon crashes all notes on scratch pad are lost.
Or am I missing something.........
As a new pilot, I would like to say well done SkyDemon
Edited 5/28/2015 6:40:31 AM by kenrcatt
I suggest you check out the following topic:-
http://forums.skydemon.aero/Topic15751.aspx#bm15782
26200.7840, SD 4.2.3
kenrcatt
kenrcatt
Posts: 4, Visits: 9
Thank you for your reply.
My point is... If or when SkyDemon crash's on my Android Google MemoPad 8, I have lost inflight information (ATIS or Squawk code)
A small point but I have gone back to paper, rather than risk it..
regards
ken
Edited 5/28/2015 6:43:39 AM by kenrcatt
You really should try the Simpleaf scratchpad app. It runs unobtrusively in the background, is launched by swiping down from the notification area and dismissed with the back button. Multiple pages are available and contents are retained until you delete them.
kenrcatt
kenrcatt
Posts: 4, Visits: 9
I will give it a try
ken
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
There is an additional app called 'last app switcher'. It gives you an additional, button to switch between SD & simpleaf. Just give it a try.
-mike
I should also mention that Simpleaf has a 'transparency mode' which allows you overlay it on top of SD (or any other app for that matter) and be able to see both apps.
kenrcatt
kenrcatt
Posts: 4, Visits: 9
Thank you both for your input.....
Happy flying....(Weather permitting)
regards
ken
