Routing difficulty on Skydemon Web
crackle
crackle
Posts: 29, Visits: 139
Recently I'm struggling to get routes to work on the web interface. If I try to load a Cloud or saved route, although the list comes up, if I click on it, the route is not displayed. I can't seem to get it to start a new route (no dialog box comes up) or even select airfields with the mouse (Options on right click are "Create a new Waypoint" or "View in Google Maps".)
I restarted the PC, tested on another PC, un- and reinstalled Silverlight.
Running XP Pro SP3, Silverlight version 5.1.30514.0, Mozilla Firefox 38.0.1., also tested in IE Version 8.0.6001.18702. IE reports the following error on the page:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.1; .NET4.0C; .NET4.0E)
Timestamp: Fri, 22 May 2015 09:24:19 UTC
Message: Unhandled Error in Silverlight 2 Application [Arg_NotSupportedException]
Arguments:
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.30514.00&File=mscorlib.dll&Key=Arg_NotSupportedException   at Divelements.SkyDemon.Planning.FlightCostRow.GetValue()
   at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.NotifyValueChanged()
   at Divelements.SkyDemon.Planning.FlightCostRow.OnFuelPlanChanged()
   at Divelements.SkyDemon.Planning.JourneyDetailRow.OnFuelPlanChanged(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Divelements.Aviation.WeightBalanceFuel.OnFuelResultsChanged(EventArgs e)
   at Divelements.Aviation.WeightBalanceFuel.UpdateFuelCalculations()
   at Divelements.SkyDemon.Planning.FuelRequiredRow.GetValue()
   at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.OnLoaded(Object sender, RoutedEventArgs e)
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
Line: 1
Char: 1
Code: 0
URI: http://web.skydemon.aero/
Arguments:
Line: 1
Char: 1
Code: 0
Arguments:
   at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.AnalyseFuelWarning()
   at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.UpdateWarnings()
   at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.OnDependentItemChanged(Object sender, EventArgs e)
   at Divelements.Aviation.Journey.EndBulkChanges()
   at Divelements.Aviation.Journey.Clear()
   at Divelements.SkyDemon.Planning.DocumentManagement.ClearRouteAndSelection(Boolean resetFilename)
   at Divelements.SkyDemon.Planning.DocumentManagement.NewRoute()
   at Divelements.SkyDemon.MainPage.OnNewButtonActivate(Object sender, EventArgs e)
   at Divelements.SandRibbon.RibbonControl.OnActivate(ActivateEventArgs e)
   at Divelements.SandRibbon.MenuItem.OnActivate(ActivateEventArgs e)
   at Divelements.SandRibbon.MenuItem.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e)
Line: 1
Char: 1
Code: 0
Thanks for any suggestions.
crackle
crackle
If it's helpful in the diagnosis, I don't have any trouble with Skydemon light on the same systems.
I just tried the web version of SD on my PC (Win 8.1) and it worked as expected. It is very likely a problem with your PC setup.
It sounds like the software is actually experiencing a crash when trying to load your route. It doesn't appear to be a widespread problem but of course we'd still like to understand and fix it. Are you able to upload the route in question here, in case it's something to do with some specific routes?
crackle
crackle
Thanks Tim
It doesn't seem at all dependent on a route, and I can't create a route either by clicking new route or clicking on airfields, but one is attached (renamed as .txt to allow upload).
Copy of Bicester.txt (1.3K views, 2.00 KB)
crackle
crackle
Thanks Chris, but you're running a different operating system.
