By crackle - 5/22/2015 9:27:10 AM
Hi Recently I'm struggling to get routes to work on the web interface. If I try to load a Cloud or saved route, although the list comes up, if I click on it, the route is not displayed. I can't seem to get it to start a new route (no dialog box comes up) or even select airfields with the mouse (Options on right click are "Create a new Waypoint" or "View in Google Maps".)
I restarted the PC, tested on another PC, un- and reinstalled Silverlight.
Running XP Pro SP3, Silverlight version 5.1.30514.0, Mozilla Firefox 38.0.1., also tested in IE Version 8.0.6001.18702. IE reports the following error on the page:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.1; .NET4.0C; .NET4.0E) Timestamp: Fri, 22 May 2015 09:24:19 UTC
Message: Unhandled Error in Silverlight 2 Application [Arg_NotSupportedException] Arguments: Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.30514.00&File=mscorlib.dll&Key=Arg_NotSupportedException at Divelements.SkyDemon.Planning.FlightCostRow.GetValue() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.NotifyValueChanged() at Divelements.SkyDemon.Planning.FlightCostRow.OnFuelPlanChanged() at Divelements.SkyDemon.Planning.JourneyDetailRow.OnFuelPlanChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at Divelements.Aviation.WeightBalanceFuel.OnFuelResultsChanged(EventArgs e) at Divelements.Aviation.WeightBalanceFuel.UpdateFuelCalculations() at Divelements.SkyDemon.Planning.FuelRequiredRow.GetValue() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.NotifyValueChanged() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.OnLoaded(Object sender, RoutedEventArgs e) at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags) Line: 1 Char: 1 Code: 0 URI: http://web.skydemon.aero/
Message: Unhandled Error in Silverlight 2 Application [Arg_NotSupportedException] Arguments: Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.30514.00&File=mscorlib.dll&Key=Arg_NotSupportedException at Divelements.SkyDemon.Planning.FlightCostRow.GetValue() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.NotifyValueChanged() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.OnLoaded(Object sender, RoutedEventArgs e) at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags) Line: 1 Char: 1 Code: 0 URI: http://web.skydemon.aero/
Message: Unhandled Error in Silverlight 2 Application [Arg_NotSupportedException] Arguments: Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.30514.00&File=mscorlib.dll&Key=Arg_NotSupportedException at Divelements.SkyDemon.Planning.FlightCostRow.GetValue() at Divelements.SkyDemon.Primitives.TextNameValuePairInteraction.NotifyValueChanged() at Divelements.SkyDemon.Planning.FlightCostRow.OnFuelPlanChanged() at Divelements.SkyDemon.Planning.JourneyDetailRow.OnFuelPlanChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at Divelements.Aviation.WeightBalanceFuel.OnFuelResultsChanged(EventArgs e) at Divelements.Aviation.WeightBalanceFuel.UpdateFuelCalculations() at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.AnalyseFuelWarning() at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.UpdateWarnings() at Divelements.SkyDemon.Planning.PlanningWarningProvisionService.OnDependentItemChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at Divelements.Aviation.WeightBalanceFuel.OnFuelResultsChanged(EventArgs e) at Divelements.Aviation.Journey.EndBulkChanges() at Divelements.Aviation.Journey.Clear() at Divelements.SkyDemon.Planning.DocumentManagement.ClearRouteAndSelection(Boolean resetFilename) at Divelements.SkyDemon.Planning.DocumentManagement.NewRoute() at Divelements.SkyDemon.MainPage.OnNewButtonActivate(Object sender, EventArgs e) at Divelements.SandRibbon.RibbonControl.OnActivate(ActivateEventArgs e) at Divelements.SandRibbon.MenuItem.OnActivate(ActivateEventArgs e) at Divelements.SandRibbon.MenuItem.OnMouseLeftButtonUp(MouseButtonEventArgs e) at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags) Line: 1 Char: 1 Code: 0 URI: http://web.skydemon.aero/
Thanks for any suggestions.
By crackle - 7/7/2015 4:22:55 PM
Thanks Chris, but you're running a different operating system.
