HTML code instead of TAF and METAR reports
Beta releases are unsupported and we would only advise someone to try them if they're running into a specific problem that we think has been fixed in a beta release, for confirmation. I will ask my colleague but I don't think we would necessary document them in the manual.
srayne
srayne
Posts: 388, Visits: 8.3K
tnowak (5/13/2015)
Hi Simon, May I suggest you put something about beta updates in your user manual?
Tony
I'm nothing but a customer and have no other affiliation to SkyDemon.
Simon
Posts: 368, Visits: 2.6K
Hi Simon,
Thanks for that info. May I suggest you put something about beta updates in your user manual? I did check but nothing was mentioned (other than to use Play Store).
Tony
srayne
srayne
Hi Tony,
Beta versions are not listed or updated through the Play Store you need to go to http://www.skydemon.aero/start/beta.aspx and download the beta version manually.
Simon
My Samsung Android device is set for automatic SD updates but no new version is showing (no "update" app option available).
Is there something else I need to do to get this beta update?
Tony
Please note that we have already fixed the issue and a beta containing the fix has been posted.
nevwright
nevwright
Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)Too Much Forum (212 reputation)
Posts: 2, Visits: 5
I have the exact same problem too. A samsung galaxy tab 2 7". Happened in the last few days. Been fantastic up to then. Hope you can help. Neville.
FaRu1
FaRu1
Posts: 35, Visits: 47
Yes, I have just now experienced the same problem with a trial version of SkyDemon, installed on a Samsung Galaxy Tab2 10.1.
Here the "Weather" and the "Pilotlog" show HTML data. The rest works fine.
Thanks Tony, this appears to be happening only on a small number of devices but we think we know why. I am going to post a beta later today with what I hope will be a fix for those devices.
I am using SD 3.3.0.18274 on my Samsung Galaxy S4 and noticed this morning that when I press the "Weather" tab I get HTML code and not the wx reports.
The "NOTAM", "PLATES" and "FLIGHT" tabs display information correctly.
Tony
