SkyDemon Navigation
HTML code instead of TAF and METAR reports
posted 5/7/2015 7:49:52 AM
Visits: 2.6K
I am using SD 3.3.0.18274 on my Samsung Galaxy S4 and noticed this morning that when I press the "Weather" tab I get HTML code and not the wx reports.
The "NOTAM", "PLATES" and "FLIGHT" tabs display information correctly.
Tony
posted 5/7/2015 9:42:16 AM
Posts: 8.2K,
Visits: 9.6K
Thanks Tony, this appears to be happening only on a small number of devices but we think we know why. I am going to post a beta later today with what I hope will be a fix for those devices.
FaRu1
FaRu1
posted 5/9/2015 5:11:24 PM
Visits: 47
Yes, I have just now experienced the same problem with a trial version of SkyDemon, installed on a Samsung Galaxy Tab2 10.1.
Here the "Weather" and the "Pilotlog" show HTML data. The rest works fine.
nevwright
nevwright
posted 5/11/2015 5:36:24 PM
Visits: 5
I have the exact same problem too. A samsung galaxy tab 2 7". Happened in the last few days. Been fantastic up to then. Hope you can help. Neville.
posted 5/12/2015 9:51:39 AM
Posts: 8.2K,
Visits: 9.6K
Please note that we have already fixed the issue and a beta containing the fix has been posted.
posted 5/13/2015 11:23:23 AM
Visits: 2.6K
My Samsung Android device is set for automatic SD updates but no new version is showing (no "update" app option available).
Is there something else I need to do to get this beta update?
Tony
srayne
srayne
posted 5/13/2015 11:48:10 AM
Visits: 8.3K
Hi Tony,
Beta versions are not listed or updated through the Play Store you need to go to
http://www.skydemon.aero/start/beta.aspx
and download the beta version manually.
Simon
posted 5/13/2015 1:17:10 PM
Visits: 2.6K
Hi Simon,
Thanks for that info. May I suggest you put something about beta updates in your user manual? I did check but nothing was mentioned (other than to use Play Store).
Tony
srayne
srayne
posted 5/13/2015 1:52:10 PM
Visits: 8.3K
tnowak (5/13/2015)
Hi Simon, May I suggest you put something about beta updates in your user manual?
Tony
I'm nothing but a customer and have no other affiliation to SkyDemon.
Simon
posted 5/13/2015 4:12:13 PM
Posts: 8.2K,
Visits: 9.6K
Beta releases are unsupported and we would only advise someone to try them if they're running into a specific problem that we think has been fixed in a beta release, for confirmation. I will ask my colleague but I don't think we would necessary document them in the manual.
