VFR Reporting Points (in Italy)
resca
resca
Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)Too Much Forum (132 reputation)
Posts: 1, Visits: 6
Due to very tricky names of our VRP's, ENAC/ENAV finally decided to assign a "Code Designator", something very similar to IFR Intersection names. They are composed by the last 2 letters of the Aerodrome ID and the 3 "cardinal" designators, like E, W1, SE2, etc. So, fo instance, in Parma CTR we no longer have to use "San't Ilario d'Enza" but a simple MPSE1. I just tried to see if SkyDemon is updated to this new (and efficient) naming, but it isn't. I just checked the on-line version and I see the long (and hard to insert in a flight plan) names. For comparison, I also loaded the France cartograpy, and I see that you use BOTH the ID's. For instance, near NICE Airport, the VRP "Sud Musee Oceanographique Monaco", is named "EC" (I would prefer MNEC, while the airporti is LFMN).
I attach the present AIP pages in which you can see the new names and I would like your opinion about the use of them or bothm or an option to choose. I would also add that the "new" 5 letter ID is what is used by Jeppesen and what is loadable in the panel-mount GPS's, due to the 5 letter limitation. With the present naming, SkyDemon is basically unuasbale for people with also one (or two...)  panel-mount GPS!
ENR6-3-1-1(3).pdf (3.8K views, 819.00 KB)
We've actually already done this work, and in the imminent 3.2.1 release you will see both the designator and long name (in brackets) for Italian VRPs.
