Nexus 7 warning and question
srayne
srayne
Posts: 388, Visits: 8.3K
I've been testing it for six hours continuously now in simulation and so far no problems at all. Great result - well done.
Simon
Hooray!
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
19 hours of simulation / flying with Xplane / all the tricks I use for a long time to stress SD.
Not a single error, not a crash.
Triple hooray! Smile
M
Taigajoe
Taigajoe
Posts: 15, Visits: 69
Android 5.02 and SD 3.2.1.23341:
-8.5 hours simulation flight without problems
- planning mode no problems, performance ok
- navigation mode: first crash after appr. 1 hours flight, second crash after another 2 hours flight. The SD app terminated complete, no freezing.
Are you sure that you are using the latest beta published yesterday (30 March)?
26200.7840, SD 4.2.3
SeanKx
SeanKx
Posts: 48, Visits: 937
How do I download the latest version please Mike? I have a 2012 Nexus and it is showing version 3.2.1.22629
Thanks,
Sean
Sean Kx
Samsung Galaxy Tab A7 Lite
Android 13
Skydemon latest version always
Hi Sean
Firstly, go to Settings>Security>Unknown Sources  and make sure that the slider switch is set to 'On' then go here:-
http://www.skydemon.aero/start/android.aspx
and tap the download link. When the download has completed, tap the file and then tap on 'Install'
Let me know if you have any problems.
SeanKx
SeanKx
Thanks Mike,
Got it. Will give it a whirl when the wind drops. I have even had occasional issues just opening SD on my Nexus as it would immediately default to the recent apps screen and also a few crashes when in nav mode. I have all the instructions here to go back to Kitkat but reluctant to do that unless necessary and I know that Tim's team will be doing everything to iron out the bugs where they can.
Sean
Sean Kx
Android 13
I've only had the opportunity to test it in simulation mode since installation, but so far, no problems at all. Looking forward to flight testing it at the weekend Smile
Taigajoe
Taigajoe
Sky Painter (3/31/2015)
No, I did not. I tested with the old beta from March 24.
I will repeat the test with the new version.
