Nexus 7 warning and question
JSAG
JSAG
Posts: 16, Visits: 242
I've just updated my Nexus 7 to v5 or lolipop or whatever Google's latest iteration is called.
The problem is non of the 'keep screen' apps seem to work on it now, including the one I had on the machine.
This is serious for navigating as the most you can hold the screen for using the settings screen is 30mins.
So if you're asked to upgrade don't, unless you know more about this stuff than I do ( not difficult)
And if you do know about this stuff can you help me with something that will keep the SkyDemon screen alive for more than 30 mins.
SkyDemon 3.2
Cheers
John
Edited 11/20/2014 11:24:39 AM by JSAG
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
19 hours of simulation / flying with Xplane / all the tricks I use for a long time to stress SD.
Not a single error, not a crash.
Triple hooray! Smile
M
Taigajoe
Taigajoe
Posts: 15, Visits: 69
Android 5.02 and SD 3.2.1.23341:
-8.5 hours simulation flight without problems
- planning mode no problems, performance ok
- navigation mode: first crash after appr. 1 hours flight, second crash after another 2 hours flight. The SD app terminated complete, no freezing.
Are you sure that you are using the latest beta published yesterday (30 March)?
6396, SD 4.1.2
SeanKx
SeanKx
Posts: 48, Visits: 936
How do I download the latest version please Mike? I have a 2012 Nexus and it is showing version 3.2.1.22629
Thanks,
Sean
Sean Kx
Samsung Galaxy Tab A7 Lite
Android 13
Hi Sean
Firstly, go to Settings>Security>Unknown Sources  and make sure that the slider switch is set to 'On' then go here:-
http://www.skydemon.aero/start/android.aspx
and tap the download link. When the download has completed, tap the file and then tap on 'Install'
Let me know if you have any problems.
6396, SD 4.1.2
SeanKx
SeanKx
Thanks Mike,
Got it. Will give it a whirl when the wind drops. I have even had occasional issues just opening SD on my Nexus as it would immediately default to the recent apps screen and also a few crashes when in nav mode. I have all the instructions here to go back to Kitkat but reluctant to do that unless necessary and I know that Tim's team will be doing everything to iron out the bugs where they can.
Sean
Sean Kx
Android 13
I've only had the opportunity to test it in simulation mode since installation, but so far, no problems at all. Looking forward to flight testing it at the weekend Smile
6396, SD 4.1.2
neilmurg
neilmurg
Posts: 42, Visits: 128
Sky Painter (3/31/2015)
Thanks Mike, got it. I'll try tomorrow. I quoted you to put the info at the back where ppl likely to look
neilmurg
Taigajoe
Taigajoe
No, I did not. I tested with the old beta from March 24.
I will repeat the test with the new version.
JSAG - 11/20/2014 11:23:06 AM
dave_kent - 11/20/2014 1:43:28 PM
Faramog - 11/24/2014 9:34:22 AM
MikeTwoOne - 11/20/2014 4:26:31 PM
JSAG - 11/20/2014 8:12:22 PM
Rob Swain - 11/30/2014 9:05:58 AM
Tim Dawson - 11/21/2014 9:52:56 AM
JSAG - 11/22/2014 10:32:24 AM
Faramog - 11/24/2014 9:03:56 AM
stevelup - 11/24/2014 11:51:30 AM
Tim Dawson - 11/24/2014 12:41:09 PM
JSAG - 11/25/2014 12:13:56 PM
srayne - 11/25/2014 3:35:38 PM
Tim Dawson - 11/25/2014 4:20:58 PM
srayne - 11/25/2014 6:26:48 PM
JSAG - 11/26/2014 12:25:39 PM
Tim Dawson - 11/26/2014 3:43:47 PM
adhawkins - 11/28/2014 12:17:44 PM
oscarbal - 12/1/2014 11:54:08 AM
adhawkins - 12/1/2014 12:24:38 PM
srayne - 12/1/2014 5:28:59 PM
JSAG - 12/5/2014 7:54:42 PM
adhawkins - 12/2/2014 12:29:38 PM
srayne - 12/3/2014 9:24:31 AM
MikeTwoOne - 12/5/2014 7:31:41 AM
Tim Dawson - 12/8/2014 5:15:32 PM
MikeTwoOne - 12/8/2014 11:58:34 PM
Sky Painter - 12/9/2014 6:11:39 PM
MikeTwoOne - 12/10/2014 12:11:59 AM
Tim Dawson - 12/10/2014 10:44:25 AM
Sky Painter - 12/10/2014 2:46:45 PM
Tim Dawson - 12/10/2014 4:08:26 PM
Sky Painter - 12/10/2014 4:14:54 PM
SteveN - 12/11/2014 9:10:17 AM
MikeTwoOne - 12/11/2014 10:42:28 AM
Sky Painter - 12/11/2014 11:12:04 AM
Tim Dawson - 12/11/2014 11:14:12 AM
Tim Dawson - 12/11/2014 12:55:18 PM
Sky Painter - 12/11/2014 4:59:08 PM
MikeTwoOne - 12/11/2014 2:06:46 PM
Tim Dawson - 12/11/2014 3:03:48 PM
MikeTwoOne - 12/11/2014 3:11:17 PM
Tim Dawson - 12/11/2014 5:04:07 PM
MikeTwoOne - 12/12/2014 2:39:29 PM
SteveN - 12/13/2014 4:40:27 PM
Sky Painter - 12/13/2014 6:48:49 PM
srayne - 12/14/2014 1:43:13 AM
SteveN - 12/15/2014 10:33:23 AM
Tim Dawson - 12/15/2014 11:38:28 AM
Sky Painter - 12/15/2014 1:06:18 PM
MikeTwoOne - 12/15/2014 2:03:14 PM
MikeTwoOne - 12/16/2014 7:08:33 AM
Tim Dawson - 12/16/2014 11:21:25 AM
Sky Painter - 12/16/2014 12:01:34 PM
MikeTwoOne - 12/16/2014 1:59:09 PM
Tim Dawson - 12/16/2014 12:15:42 PM
Sky Painter - 12/16/2014 12:45:12 PM
     Thanks!
Tim Dawson - 12/16/2014 5:19:55 PM
Tim Dawson - 12/19/2014 11:57:39 AM
     Thanks Tim.
SteveN - 12/20/2014 10:21:20 AM
Sky Painter - 12/21/2014 12:51:16 PM
Tim Dawson - 12/23/2014 11:22:40 AM
Sky Painter - 12/23/2014 1:51:25 PM
Tim Dawson - 12/24/2014 12:18:54 PM
Sky Painter - 12/24/2014 2:30:48 PM
Sky Painter - 12/30/2014 10:23:58 AM
Tim Dawson - 1/5/2015 12:34:20 PM
Sky Painter - 1/5/2015 1:44:17 PM
Tim Dawson - 1/6/2015 11:07:15 AM
Sky Painter - 1/6/2015 1:45:22 PM
Sky Painter - 1/9/2015 10:58:11 PM
Tim Dawson - 1/12/2015 11:25:19 AM
Sky Painter - 1/12/2015 12:44:59 PM
Tim Dawson - 1/13/2015 12:33:02 PM
Sky Painter - 1/13/2015 6:26:15 PM
wb9999 - 1/19/2015 2:20:40 PM
Sky Painter - 1/19/2015 5:29:46 PM
SteveN - 1/20/2015 10:51:04 AM
srayne - 1/20/2015 1:26:01 PM
Sky Painter - 1/21/2015 11:33:56 AM
srayne - 1/21/2015 1:04:39 PM
Tim Dawson - 1/21/2015 12:06:43 PM
MikeTwoOne - 1/27/2015 11:01:32 AM
Sky Painter - 1/27/2015 1:14:38 PM
Joseph Cullen - 1/24/2015 5:07:36 PM
Tim Dawson - 1/26/2015 12:36:14 PM
Sky Painter - 1/26/2015 2:36:13 PM
Joseph Cullen - 1/27/2015 10:10:16 AM
Tim Dawson - 1/26/2015 3:57:33 PM
Sky Painter - 1/26/2015 10:48:00 PM
srayne - 1/27/2015 9:02:23 AM
srayne - 1/27/2015 1:15:55 PM
Tim Dawson - 1/28/2015 10:47:35 AM
Tim Dawson - 2/5/2015 11:33:09 AM
srayne - 2/5/2015 4:12:21 PM
SteveN - 2/5/2015 5:00:04 PM
srayne - 2/6/2015 1:00:19 PM
Tim Dawson - 2/6/2015 11:48:32 AM
adhawkins - 2/10/2015 12:12:19 PM
Sky Painter - 2/10/2015 12:57:28 PM
dave_kent - 2/10/2015 1:17:37 PM
Joseph Cullen - 2/10/2015 1:51:24 PM
adhawkins - 2/10/2015 2:03:23 PM
PeterGristwood - 2/10/2015 2:19:15 PM
Sky Painter - 2/10/2015 2:57:24 PM
Joseph Cullen - 2/10/2015 3:43:33 PM
Tim Dawson - 2/10/2015 4:33:21 PM
SteveN - 2/11/2015 11:06:11 PM
DirDej - 2/10/2015 7:34:26 PM
srayne - 2/11/2015 7:52:29 AM
T67M - 2/12/2015 8:52:21 AM
Tim Dawson - 2/11/2015 11:22:31 AM
Sky Painter - 2/11/2015 11:43:42 AM
MikeTwoOne - 2/11/2015 1:39:02 PM
Tim Dawson - 2/12/2015 12:28:13 PM
DirDej - 2/12/2015 8:28:13 PM
JSAG - 2/12/2015 11:56:57 PM
Sky Painter - 2/13/2015 10:03:33 AM
JSAG - 2/13/2015 4:08:38 PM
JSAG - 2/13/2015 4:18:22 PM
                         Hi John Ah! Now I understand. Android 4.4.2 is KitKat (your...
Sky Painter - 2/13/2015 6:07:57 PM
Tim Dawson - 2/13/2015 4:39:29 PM
Pete - 2/13/2015 7:45:36 PM
Joseph Cullen - 2/18/2015 1:16:52 PM
SteveN - 2/19/2015 9:10:01 AM
srayne - 2/19/2015 11:44:52 AM
Pete - 2/19/2015 2:22:15 PM
Tim Dawson - 2/20/2015 12:48:05 PM
srayne - 2/20/2015 2:40:01 PM
DirDej - 2/23/2015 6:00:53 AM
Sky Painter - 2/28/2015 12:03:04 PM
                         A few 5.1.0 factory images starting to appear now:...
SteveN - 3/10/2015 8:04:46 AM
Tim Dawson - 3/11/2015 5:13:00 PM
srayne - 3/12/2015 8:20:48 AM
srayne - 3/12/2015 1:06:30 PM
Tim Dawson - 3/12/2015 5:31:32 PM
srayne - 3/13/2015 7:58:29 AM
Barry - 3/12/2015 10:09:46 PM
     Thanks Simon.
Tim Dawson - 3/16/2015 10:23:24 AM
adhawkins - 3/17/2015 2:59:11 PM
Sky Painter - 3/17/2015 3:46:40 PM
adhawkins - 3/18/2015 12:21:12 PM
Rhoditis - 3/21/2015 3:21:40 PM
PeterGristwood - 3/23/2015 12:16:59 AM
Taigajoe - 3/23/2015 8:18:12 AM
DirDej - 3/23/2015 10:45:36 AM
GEAR - 3/23/2015 11:35:30 AM
                         [quote][b]GEAR (3/23/2015)[/b][hr]I had problems with SD "dropping...
Sky Painter - 3/23/2015 3:00:28 PM
Sky Painter - 3/23/2015 2:54:33 PM
DirDej - 3/23/2015 5:08:19 PM
GEAR - 3/23/2015 6:56:20 PM
Tim Dawson - 3/24/2015 3:02:08 PM
srayne - 3/24/2015 5:32:47 PM
GEAR - 3/24/2015 9:02:08 PM
MikeTwoOne - 3/29/2015 1:48:49 PM
Tim Dawson - 3/30/2015 10:40:49 AM
Sky Painter - 3/30/2015 12:31:42 PM
MikeTwoOne - 3/30/2015 10:53:26 AM
Tim Dawson - 3/30/2015 2:55:07 PM
MikeTwoOne - 3/30/2015 3:18:44 PM
srayne - 3/30/2015 5:00:32 PM
     Hooray!
Tim Dawson - 3/30/2015 7:49:20 PM
MikeTwoOne - 3/31/2015 7:02:05 AM
Taigajoe - 3/31/2015 8:10:48 AM
Sky Painter - 3/31/2015 8:41:19 AM
SeanKx - 3/31/2015 9:16:56 AM
                         Hi Sean Firstly, go to Settings>Security>Unknown Sources and...
Sky Painter - 3/31/2015 9:32:14 AM
                             Thanks Mike, Got it. Will give it a whirl when the wind drops. I have...
SeanKx - 3/31/2015 9:53:51 AM
                                 I've only had the opportunity to test it in simulation mode since...
Sky Painter - 3/31/2015 10:49:28 AM
                             [quote][b]Sky Painter (3/31/2015)[/b][hr]Firstly, go to...
neilmurg - 4/15/2015 12:11:05 PM
Taigajoe - 3/31/2015 11:04:11 AM
srayne - 4/1/2015 6:39:41 AM
Sky Painter - 4/1/2015 11:22:31 AM
srayne - 4/1/2015 11:35:37 AM
PeterGristwood - 4/1/2015 11:10:55 AM
srayne - 4/1/2015 11:37:33 AM
PeterGristwood - 4/1/2015 10:55:47 PM
GEAR - 4/2/2015 7:23:56 AM
                         [quote][b]GEAR (4/2/2015)[/b] See the section labelled "Razor". As of...
MikeTwoOne - 4/2/2015 12:52:58 PM
                             [quote][b]MikeTwoOne (4/2/2015)[/b][hr][quote][b]GEAR (4/2/2015)[/b]...
srayne - 4/2/2015 1:07:58 PM
                                 Latest beta seems very stable on 4.4.4 & 5.0.2 , better than I have...
Pete - 4/2/2015 2:42:50 PM
                                     I used the new beta for a full day in the car last week and it worked...
Swish - 4/5/2015 8:03:50 PM
                                         Hi, I tested Android 5.02 and SD 3.2.1.18152 at the last days: 4...
Taigajoe - 4/6/2015 3:27:59 PM
                                             4 hours in the car today for work so tested SD latest Beta version on...
SeanKx - 4/6/2015 7:30:18 PM
MikeTwoOne - 4/7/2015 6:50:26 AM
Tim Dawson - 4/7/2015 10:44:27 AM
adhawkins - 4/7/2015 11:44:37 AM
Tim Dawson - 4/7/2015 2:06:41 PM
adhawkins - 4/8/2015 8:29:02 AM
PeterGristwood - 4/8/2015 9:20:15 AM
             Any news when it will be on play store?
Rowan - 4/22/2015 7:06:44 PM
Sky Painter - 4/23/2015 6:50:15 AM
Rowan - 5/3/2015 8:26:42 PM
adhawkins - 4/8/2015 11:39:55 AM
Pete - 4/8/2015 11:12:19 PM
Gonk - 4/23/2015 2:37:34 PM
Tim Dawson - 5/5/2015 9:42:23 AM
DirDej - 5/14/2015 7:24:34 AM
Tim Dawson - 5/14/2015 9:14:47 AM
