Native bluetooth GPS support for android
elphil
elphil
Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)Too Much Forum (130 reputation)
Posts: 1, Visits: 1
I use a Garmin GLO Bluetooth GPS, but to use it with SkyDemon it's a bit inconvenient because I have to launch a separate app which acts as a "Mock GPS Provider".
Would it be possible to have native bluetooth GPS support within SkyDemon?
Thanks,
Philipp
Michel RIAZUELO
Michel RIAZUELO
Posts: 11, Visits: 92
elphil (11/07/2014)
... I have to launch a separate app which acts as a "Mock GPS Provider"...
Yes, and it works fine with Bluetooth GPS (ANDROID) for example ...
Why would complicate SD while a good solution exist ?
Michel
The solution you mentioned is THE solution for using Bluetooth GPS devices on Android. If you want proper native support, talk to Google.
Michel RIAZUELO
Michel RIAZUELO
Sorry Tim, look at ORUX MAP which can use internal or BT external GPS without other app.
See a screnshot here .
But I confirm that using BLUETOOTH GPS with SD is not a limitation. And this allow to control precisely the reception quality.
Michel
That just means that particular app has implemented support for a particular third-party Bluetooth GPS. Good for them, but with the large number of such devices in use we will not be devoting our resources to reinventing this particular wheel. It just isn't worth the effort when a solution already exists.
Michel RIAZUELO
Michel RIAZUELO
YEEES !
