SkyDemon Navigation
Native bluetooth GPS support for android
elphil
elphil
posted 7/11/2014 6:42:11 PM
Visits: 1
I use a Garmin GLO Bluetooth GPS, but to use it with SkyDemon it's a bit inconvenient because I have to launch a separate app which acts as a "Mock GPS Provider".
Would it be possible to have native bluetooth GPS support within SkyDemon?
Thanks,
Philipp
Michel RIAZUELO
Michel RIAZUELO
posted 7/12/2014 8:01:21 AM
Visits: 92
elphil (11/07/2014)
... I have to launch a separate app which acts as a "Mock GPS Provider"...
Yes, and
it works fine
with
Bluetooth GPS
(ANDROID)
for example ...
Why would
complicate
SD
while
a good solution exist ?
Michel
posted 7/14/2014 1:52:54 PM
Posts: 8.3K,
Visits: 9.9K
The solution you mentioned is THE solution for using Bluetooth GPS devices on Android. If you want proper native support, talk to Google.
Michel RIAZUELO
Michel RIAZUELO
posted 7/21/2014 7:31:52 AM
Visits: 92
Sorry Tim, look at
ORUX MAP
which can use internal or BT external GPS without other app.
See a screnshot
here
But I confirm that using BLUETOOTH GPS with SD is not a limitation. And this allow to control precisely the reception quality.
Michel
posted 7/21/2014 11:54:00 AM
Posts: 8.3K,
Visits: 9.9K
That just means that particular app has implemented support for a particular third-party Bluetooth GPS. Good for them, but with the large number of such devices in use we will not be devoting our resources to reinventing this particular wheel. It just isn't worth the effort when a solution already exists.
Michel RIAZUELO
Michel RIAZUELO
posted 7/21/2014 2:50:18 PM
Visits: 92
YEEES !
