New beta version 1.3.3
Steve
Steve
Posts: 55, Visits: 123
When clicking on the fuel for the planned section in the flight details box I get the following error, on two different computers the error is the same.
Regards, Steve
System.InvalidOperationException: The attempted operation is not valid when no editor is active.
   at Divelements.SandGrid.SandGridBase.set_EditorDirty(Boolean value)
   at Divelements.SandGrid.GridUpDownEditor.OnValueChanged(EventArgs e)
   at System.Windows.Forms.NumericUpDown.set_Value(Decimal value)
   at System.Windows.Forms.NumericUpDown.set_Minimum(Decimal value)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.xdce26a76befdc69e.ConfigureEditor(IGridCellEditor editor)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.x64049722ec769c30(Object xe0292b9ed559da7d, GridBeforeEditEventArgs xfbf34718e704c6bc)
   at Divelements.SandGrid.SandGridBase.OnBeforeEdit(GridBeforeEditEventArgs e)
   at Divelements.SandGrid.SandGridBase.BeginEdit(GridRow row, GridColumn column, Boolean selectAll)
   at Divelements.SandGrid.GridRow.BeginEdit(GridColumn column)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.xdce26a76befdc69e.StartEdit()
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.x3c5f9adba303fb78.OnMouseDown(MouseEventArgs e)
   at Divelements.SandGrid.x5d3666f49ba1c366.x35085a23be2a381a(SandGridBase x3040c866fac95193, MouseEventArgs xfbf34718e704c6bc)
   at Divelements.SandGrid.SandGridBase.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at Divelements.SandGrid.SandGridBase.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.3.3.21000
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.3863.20998
    Win32 Version: 1.0.3863.20998
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
    Assembly Version: 2.2.3.1
    Win32 Version: 2.2.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
System
System.Drawing
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    Assembly Version: 1.0.3863.20997
    Win32 Version: 1.0.3863.20997
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
Steve
Steve
Two other points i notices with the new beta version.
1. If you have a shortcut on your desktop to the skydemon plan software it doesn't work after the instal of the new beta version (it didn't work after the install of any of the previous upgrades either, can the install program ask if you want a desktop shortcut, like some other software installs ?
2. if you move the 'ribbon' menu bars at the top of the screen to be side-by-side instead of one underneath the other (better use of the screen area) when closing the software down, or exiting the setting is lost and you have to move the menu bar every time you load up the software, can the position be remembered ?
Regards, Steve
The first error you posted makes it look like you have installed the beta over the top of a previous version, which would fail to replace a critical file. This is why the beta webpage specifically asks you to uninstall any previous version first. Apologies if this isn't the case but it's the only thing I can think of.
The shortcut recreation issue is something we're aware of but currently can't do anything about.
We'll see if we can start saving toolbar layout too. It's encourating to discover that someone has worked out they are movable!
Steve
Steve
After a complete uninstall and then a clean reinstall everything appears to work well. However for the flight fuel I did prefer the old slider from the previous version.
Steve
I preferred the slider too.
Steve
Steve
Another comment, I have exported a load of personal waypoints from one desktop PC so that I can import them on my other desktop PC (Home and work PC's), the export worked perfectly (or seemed to), then when I try and import the waypoints on the other PC I get the following error.....
"Object reference not set to an instance of an object"
Any clues, Steve
Sounds like a good one, is there any additional information?
Steve
Steve
Tim,
That message is contained in a box that all I can do is click the OK button and it goes away.
This morning I tried to make a new export from my source PC of the waypoints (file attached), again that seemed to work OK, I then tried to import the file back into the same PC, I get the error as before.
Cheers, Steve
Thanks, found and fixed.
Steve
Steve
I can confirm that with the latest beta version the waypoints problem above is fixed and now works perfectly, also I like the return of the fuel slider !
Thanks, Steve
