New beta version 1.3.3
http://forums.skydemon.aero/Topic840.aspx
By Steve - 8/1/2010 5:46:32 PM
When clicking on the fuel for the planned section in the flight details box I get the following error, on two different computers the error is the same.
Regards, Steve
System.InvalidOperationException: The attempted operation is not valid when no editor is active.
   at Divelements.SandGrid.SandGridBase.set_EditorDirty(Boolean value)
   at Divelements.SandGrid.GridUpDownEditor.OnValueChanged(EventArgs e)
   at System.Windows.Forms.NumericUpDown.set_Value(Decimal value)
   at System.Windows.Forms.NumericUpDown.set_Minimum(Decimal value)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.xdce26a76befdc69e.ConfigureEditor(IGridCellEditor editor)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.x64049722ec769c30(Object xe0292b9ed559da7d, GridBeforeEditEventArgs xfbf34718e704c6bc)
   at Divelements.SandGrid.SandGridBase.OnBeforeEdit(GridBeforeEditEventArgs e)
   at Divelements.SandGrid.SandGridBase.BeginEdit(GridRow row, GridColumn column, Boolean selectAll)
   at Divelements.SandGrid.GridRow.BeginEdit(GridColumn column)
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.xdce26a76befdc69e.StartEdit()
   at Divelements.Aviation.FlightPlanner.UI.x3381580aa1dd6906.x3c5f9adba303fb78.OnMouseDown(MouseEventArgs e)
   at Divelements.SandGrid.x5d3666f49ba1c366.x35085a23be2a381a(SandGridBase x3040c866fac95193, MouseEventArgs xfbf34718e704c6bc)
   at Divelements.SandGrid.SandGridBase.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at Divelements.SandGrid.SandGridBase.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 1.3.3.21000
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.3863.20998
    Win32 Version: 1.0.3863.20998
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
    Assembly Version: 2.2.3.1
    Win32 Version: 2.2.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
System
System.Drawing
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    Assembly Version: 1.0.3863.20997
    Win32 Version: 1.0.3863.20997
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
By Steve - 8/10/2010 11:14:14 AM
I can confirm that with the latest beta version the waypoints problem above is fixed and now works perfectly, also I like the return of the fuel slider !
Thanks, Steve
