WP names in ICAO flight plans
milansmid
milansmid
Posts: 68, Visits: 565
Hello Tim,
I got an answer from ICAO regarding this issue. As a reminder - I asked whether I can use 4 letter ICAO codes of airports in the Route section. The ICAO officer confirm that I can.
Dear Mr. Smid.
Thanks for your consultation.
Your interpretation on how to fill Item 15 (route) of the FPL form is correct.
Regarding the interpretation of “Significant point” I’d like to highlight that you also have the definition of “Reporting point” and in your case, the airport 4 letters designator is considered a reporting point instead of a significant point due to the definition of both.
Reporting point is a ”Specified geographical location in relation to which the position of an aircraft can be reported.”
Significant point , although has the same use, is defined as a ground-based navigation aid, an intersection and/or waypoint. And in this context, intersection is a significant point expressed as radials, bearings and/or distances from ground-based navigation aids.
As you can see there is a slight difference, in terms of definition, between the two, but again, your interpretation on the way to fill Item 15 is correct.
Best regards,
Saulo
Saulo Silva
Technical Officer
International Civil Aviation Organization
Air Traffic Management Section
Well, that's a clear message at least. Tim, can you point me to the source from where you determine what is or isn't ICAO compatible, please? I (and others) seem to have differeing information on this.
The reason I ask is because I just checked ICAO document PANS-ATM, 4444 which defines the standard format of an ICAO flight plan. (If you want to check, a simple Google search will get you there.) The assertion of yours, that route points have to be specified as coordinates, is simply not supported by ICAO standard. It clearly says (and I quoted from it before) that for flights not following prescribed ATS routes, significant points along the route should be added as
The coded designator (2 to 5 characters) assigned to the point (e.g. LN, MAY, HADDY), or, if no coded designator has been assigned, one of the following ways:
-- Degrees only (7 characters)
-- Degrees and minutes (11 characters)
-- Bearing and distance from a significant point
Specifically, regarding the specification of border crossing points, so called "boundary points" the ICAO standard document says:
The BOUNDARY POINT expressed either by a designator consisting of 2 to 5 characters, in Geographical Coordinates, in Appreviated Geographical Coordinates, or by bearing and distance from a significant point.
This point may be an agreed point located close to, rather than on, the FIR boundary.
So, clearly, if I choose a point for my route for which a coded designator has been assigned then I am REQUIRED to use that designator in the route definition. Strictly speaking, the flight plan SD generates by substituting coordinates in cases where a coded designator exists are not ICAO compliant.
Also, the use of GOLVA as border crossing point in the example I gave near the beginning of the thread is fully compliant with the ICAO standard.
You wrote:
Airfield ICAO codes, towns and VRPs are things which absolutely are not allowed in the route section of a flightplan.
I hope I was able to convince you that airfield codes and VRPs are REQUIRED to be used as such in an ICAO flight plan. About towns I fully agree with you. The rule is that you have to use the CODED DESIGNATOR if one exists. If there's none then you use one of the other methods (geographical coordinates, abbreviated geographical coordinates or distance/bearing from a significant point).
Regarding the use of "DCT" in the route description the standard document has this to say:
Insert DCT between successive points unless both points are defined by geographical coordinates or by bearing and distance.
In this respect we were both wrong. Since SD gives all points as geographical coordinates there shouldn't be a DCT interspersed between them. And as I, in my own flight plans, give those points as coded designators I should have DCT between successive points.
I realize, of course, that you are the "Game Master" in as far as you can evolve SD in any direction you like. No qualms about that. And, by the way, I do love SD and think it is currently the best flight planning software out there for European VFR pilots.
But if you point to ICAO requirements as justification for only allowing route points as coordinates then that is something that is not supported by ICAO standard.
Edited 9/6/2012 9:08:23 AM by ckurz7000
I said in page 2 that there is not a solution to this that we can give you. We are not willing to produce flightplans in a format that we know is not ICAO-compliant, as various organisations would instantly reject such flightplans. Airfield ICAO codes, towns and VRPs are things which absolutely are not allowed in the route section of a flightplan.
We don't plan on adding an option which would generate such plans because even if we did, there would be disagreement about the format of VRP names. Instead we will generate an ICAO-compliant machine-readable flightplan and you are free to manipulate it as you wish before it is filed.
Just a bump up post, really. It would be great to get a yes or no from Tim. Right now this seems to be in limbo...
- Chris.
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Have you ever wondered why you always have to tell the ATC FIS everything about your VFR flight about route/type/altitude/dep/dest, and not when flying IFR? For a national flight that is explainable, but for an FIR crossing flight there should be a FPL right?
As said before, VFR plans are just notifications, and mostly nobody cares about them when you are up in the air.
It's not the case in France - if you file a VFR flight plan there, they have your details when you call up the SIV.
0fficer
0fficer
Posts: 6, Visits: 94
That is probably the previous ATC unit giving your details to the next.
That my very well be the case but on vfr flights crossing FIR boundaries ATC did know about my flightplan and greeted my in the air with all the details already in front of them, just like when flying ifr.
0fficer
0fficer
ckurz7000 (29/08/2012)
... They are read by a machine, their syntax is checked by a machine. When everything checks out they are submitted into the Eurocontrol system and percolate down to the necessary stations there. If the syntax happens to be incorrect (such as, e.g., you entered a non-existant airport ID or specified wrong equipment codes or any other such thing) the flightplan is thrown right back at you.
VFR flight plans have nothing to do with Eurocontrol. Only a IFR FPL goes through the system of Eurocontrol. I believe most national authorities require the VFR FPL filing going through some authorised system (Holland, Belgium, France) and are checked by them. UK has a more relaxed attitude to that, that's why Rocketroute, SD, EuroFPL have their origin there.
VFR plans are send to their destinations directly. SD (or their filing partner EuroFPL) checks the content and they just send the FPL according to the VFR addressing guide to their intended destinations. VFR plans are actually just a notification. If anything along the route is not allowed, you will hear it on the radio or you receive a call from the complaining authority.
milansmid
milansmid
Chris,
This is quite interesting what you're writting...
I understand why Tim is reluctant to change the system as the product he sells cannot create any doubts about (not)complying with the applicable rules. And whether the use of airport ICAO designators in the Route section of the ICAO flight plan is compliant or not is apparently not entirely clear.
On the other hand let me put your quote to a broader picture:
The definition you quote in your post comes from the ICAO Doc.4444 Procedures for Air Navigation Services - Air Traffic Management which governs also the flight plans. This "core" regulation seems to be transposed to the national AIPs.
The above mentioned document states that the Route (Item 15 in the ICAO flight plan), in case of Flights outside designated ATS routes (so I'd say in almost all VFR flights), can be filled in also by using so called Significant points (2 to 11 characters) - the coded designator (2 to 5 characters) assigned to the point.
In the same document, ICAO defines the Significant point as a specified geographical location used in defining an ATS route or the flight path of an aircraft and for other navigation and ATS purposes.
So the whole problem boils down to a question whether an airport defined by the four letter ICAO code is a Significant point as defined by ICAO.
To my understanding, it is - as it is a specified geographical location.
Nevertheless, I have sent an e-mail to ICAO asking them to confirm this interpretation. Now I have to wait and see if a little General Aviation VFR pilot matters to them or not Smile
Tim: I can confirm that none of my flight plans were returned to me because of using a four letter ICAO codes of airports in the Route section. I have been filing by paper, fax, on-line formulaire of Belgocontrol, and by SkyDemon.
Once (if) I receive an answer from ICAO I will post it here.
Milan
Tim, I don't know where you fly but in Germany, France, Austria, Czechia, Slovakia, Hungary, Slovenia and Croatia what you say is not true. I have filed flight plans in each of those countries using an online briefing system such as, e.g., Olivia in France or homebriefing.com in most other countries to file flight plans. They are read by a machine, their syntax is checked by a machine. When everything checks out they are submitted into the Eurocontrol system and percolate down to the necessary stations there. If the syntax happens to be incorrect (such as, e.g., you entered a non-existant airport ID or specified wrong equipment codes or any other such thing) the flightplan is thrown right back at you.
NEVER have I had a problem with putting VFR-rep points by name in the flight plans.
I just checked instructions on how to file an ICAO flight plan and found the following:
When not on ATS routes, the route may be specified using significant points along the route using 2 to 11 characters. The coded designator assigned to the point may be used (e.g., LN, MAY, HADDY). If no coded designator has been assigned, use one of the following:
Degrees only (7 characters) or degrees and minutes (11 characters).
I also checked the official guide lines of Austro Control which were updated in 2012 to reflect some changes made in the filing format (concerning the equipment codes and other information fields). Attached is a VFR flight plan specifically given as an example in their instructions. The flight is from LOWW to LHFM. The point at which the flight exits LOWW CTR is S and the border crossing point is SOPRON. Both NEED to be given as names in the route field.
Furthermore, Austro Control states that extraneous DCT's are to be avoided. Therefore there is NO DCT anywhere in this flightplan. DCT is only to be used when joining or leaving an ATS route.
VFR Flight Plan.JPG (1.4K views, 91.00 KB)
Edited 8/29/2012 3:55:59 PM by ckurz7000
