IPAD flight log transfer to PC SD
LinasAnd
LinasAnd
Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)Too Much Forum (314 reputation)
Group: Awaiting Activation
Posts: 1, Visits: 12
When I transfer flight history log file from my ipad to pc via iTunes, the extenion of the file is flightlog which I do not know how to open in SD PC version, as when I try to import from file, the SD program does not see the mentioned file extension. (It is looking only gpx extension). Question:
how do I get logs from ipad to SD PC version? Second question, can you add either to IPAD version or to both versions, so that logs of the flights would be ready for printouts and record keeping according to official rules. Basically can you add logbook capability to the program: you start skydemon, you plan, you fly, and you go home and all teh flight data, touchdowns and so on are recorded according to actual flight for later review and printouts.
Thanks in adnvance, I am happy with your program otherwise.
Linas
Posts: 8.1K, Visits: 9.4K
Flight logs live in the SkyDemon\Logs folder in your My Documents folder on your PC. Putting a log in there will result in it showing up when you go to review a log in SkyDemon Plan.
We do not currently intend to introduce a full logbook facility in SkyDemon, but when you analyse a flight log it should show you everything you need to easily create a log entry elsewhere.
thomas-iff
thomas-iff
Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)Too Much Forum (275 reputation)
Posts: 1, Visits: 2
Dear Team,
I have the same problem: I have imported my flight logs from the iPad to PC using iTunes. Afterwards I copied it to the ..\Documents\SkyDemon\Logs-Folder. Now they appear in the "Open Flight Log"-window after starting SkyDemon on my PC. But they are greyed out and I can not click "OK" or double-click the log files itself. Can you help me how to display the logfiles in my PC after my flight(s)?
Thanks a lot,
Thomas
LinasAnd - 8/12/2012 10:26:01 AM
Tim Dawson - 8/20/2012 2:58:42 PM
thomas-iff - 9/21/2012 4:05:59 PM
Tim Dawson - 9/24/2012 1:13:05 PM
AlanS - 9/30/2012 3:58:05 PM
Tim Dawson - 10/1/2012 11:42:24 AM
AlanS - 10/1/2012 6:30:30 PM
2greens1red - 10/2/2012 12:01:23 AM
AlanS - 10/2/2012 5:38:27 AM
EricSp - 10/2/2012 10:00:04 AM
thankershow - 1/1/2013 5:59:24 AM
                         When I email a track log from my ipad and then try to open the .gpx...
UniformFoxtrot - 7/12/2013 11:40:51 AM
                             I found an application, DiskAid, that allows moving files as you like...
guille - 7/12/2013 12:00:01 PM
                                 Thanks Guille. I was trying to send the log to someone else rather...
UniformFoxtrot - 7/12/2013 4:03:34 PM
longfinals - 11/3/2012 5:23:22 PM
Jimbo - 11/12/2012 10:02:47 PM
Jimbo - 11/12/2012 10:06:21 PM
Tim Dawson - 7/16/2013 12:34:41 PM
