When I transfer flight history log file from my ipad to pc via iTunes, the extenion of the file is flightlog which I do not know how to open in SD PC version, as when I try to import from file, the SD program does not see the mentioned file extension. (It is looking only gpx extension). Question:
how do I get logs from ipad to SD PC version? Second question, can you add either to IPAD version or to both versions, so that logs of the flights would be ready for printouts and record keeping according to official rules. Basically can you add logbook capability to the program: you start skydemon, you plan, you fly, and you go home and all teh flight data, touchdowns and so on are recorded according to actual flight for later review and printouts.
Thanks in adnvance, I am happy with your program otherwise.
Linas
