Skydemon upload to Garmin GPSmap495
robbinia
robbinia
Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)Too Much Forum (269 reputation)
Posts: 2, Visits: 32
I've been using Skydemon for a couple of weeks now and think it's a fantastic product.
One issue I have come across is when I plan multiple routes and upload to the GPS, one after the other.
I plan a route (e.g. Fairoaks to Sandown) and save/upload to GPSmap495 OK.
I press "new route" and plan a second leg (e.g. Sandown to Compton Abbas). When I upload, there's no transfer and Skydemon hangs. I have to kill it via Windows Task Manager which takes ages.
This is incredibly frustrating and happens every time.
Can you please look into this ?
robbinia
robbinia
I've played around with different ways of transferring routes and had the same issue each time:
Does each route have just 1 leg?
it doesn't seem to make any difference
Do you rename the routes from the ones suggested by SD?
Which Garmin transfer method do you use .. via Setup/Devide connectivity or via Go Flying/Send route?
BUT I have found a way to consistently transfer routes, one after the other, from PC to GPSmap495 - unplug the USB cable from the PC and replug between transfers. This way I can transfer routes with multiple legs and renamed as I want each time.
Not ideal but at least it's usable approach.
Any other suggestions would be great!
Thanks.
