I've played around with different ways of transferring routes and had the same issue each time:
Does each route have just 1 leg?it doesn't seem to make any differenceDo you rename the routes from the ones suggested by SD?
it doesn't seem to make any differenceWhich Garmin transfer method do you use .. via Setup/Devide connectivity or via Go Flying/Send route?
BUT I have found a way to consistently transfer routes, one after the other, from PC to GPSmap495 - unplug the USB cable from the PC and replug between transfers. This way I can transfer routes with multiple legs and renamed as I want each time.
Not ideal but at least it's usable approach.
Any other suggestions would be great!
Thanks.
