SD (reliably) crashing
matthew_w100
matthew_w100
Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)Too Much Forum (224 reputation)
Posts: 23, Visits: 54
Yesterday I was having trouble with SD reliably crashing and shutting down.  This happened whenever I tried to use the "spinner" wigit to change my take-off time on a route.  I had flown Redhill to Calais and wanted to reverse the route for the flight back.  As i needed a flight plan I needed to enter an accurate flight departure time.  I pulled up the "flight details panel, went to Take-off and tried to spin the hour number.  SD shut down.  I repeated this several times with both the hours and minutes spinner.  After a few moments of incredulity (SD is normally SO reliable) I realised I could type in the numbers I needed and that worked ok.  I had similar problems when I wanted to delay my resulting flight plan - adjusting the departure time through the "Manage my flight plan" facility caused similar crashes and I ended up having to delete the flight plan and create a new one.
This activity was on a Samsung S22Ultra.  With Android 15.  A significant point is the phone had just updated to One UI version 15.
SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)SkyDemon Team (681K reputation)
Posts: 8.1K, Visits: 9.5K
There is a bug in that One UI version of Android. We have not managed to find any way around it on the SkyDemon side.
matthew_w100
matthew_w100
Tim Dawson - 5/12/2025 9:24:18 AM
No worries then.  I hate spinners anyway; I'll just type the number in now I know.  Is the spinner problematic wherever it appears?  And are there other similar bugs in One UI that it would be worth being aware of?
I can only imagine it doesn't work anywhere, based on what I know about the problem. I don't use One UI so don't know any more.
cda
c
Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)Forum Newbie (5 reputation)
Posts: 3, Visits: 0
Tim Dawson - 5/16/2025 1:52:55 PM
I’m experiencing exactly the same issue when setting the flight time and when sending a delay notification for the flight plan.
I also wasn’t able to manually enter a time to shift it, so I had to do it by phone with DFS.
The issue seems to have started after the update to OneUI 7.0 / Android 15, and I’m using SkyDemon version 4.0.2.0.
I also tried installing SkyDemon on my wife’s phone, but failed right after login during the chart download. Instead of being presented with a country selection, the download starts immediately, but nothing happens — probably because no country is selected. When tapping the back button, you briefly see the country selection menu, but it closes right away and takes you back to the welcome screen.
The same OneUI, Android, and SkyDemon versions are installed on that phone.
Could this also be related to the new OneUI or Android version?
Christian
Johannes B.
J
Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)Too Much Forum (596 reputation)
Posts: 51, Visits: 1
Same problem here on my S23. I also can not use the manual input method this leads to a crash as well or the digits are not imported.
YouTube channel
We released 4.0.4 for Android over the weekend which replaces the buggy Android time picker with a simple textbox.
cda, could you contact customer support about the issue on your wife's phone, if it's repeatable?
Johannes B.
J
Tim Dawson - 6/2/2025 9:24:15 AM
Problem solved, thanks!
YouTube channel
Posts: 361, Visits: 2.5K
Just a query regarding SkyDemon versions information.
I have an Android Samsung S22+ and when I click on "Help/About SkyDemon" it says I have version 4.0.4.0 loaded.
I think this is the latest version.
When I click on "Help/Version History" its mentions:
Version 4.1.0 (forthcoming)
Version 4.0.2 (30 Jan 2025)
Version 4.0.1 (21 Nov 2024)
Version 4.0.0 (22 Aug 2024)
etc.
No mention of version 4.0.4.0 which is the current release.
It would appear that version 4.0.3 got binned...?
Just a comment regarding "forthcoming" version info.
Wouldn't it be better to supress this information until the version has actually been pushed?
Lots of people have been using 4.1 in beta for months, and we have no problem with people knowing what the forthcoming version is going to bring.
Occasionally we will do a small release to fix something in one platform (iOS) where nothing needs fixing in Android, for example. That's what happened to 4.0.3. Rest assured that anything worth documenting is documented on the version history page.
