SD (reliably) crashing
matthew_w100
matthew_w100
Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)Too Much Forum (456 reputation)
Posts: 25, Visits: 57
Yesterday I was having trouble with SD reliably crashing and shutting down.  This happened whenever I tried to use the "spinner" wigit to change my take-off time on a route.  I had flown Redhill to Calais and wanted to reverse the route for the flight back.  As i needed a flight plan I needed to enter an accurate flight departure time.  I pulled up the "flight details panel, went to Take-off and tried to spin the hour number.  SD shut down.  I repeated this several times with both the hours and minutes spinner.  After a few moments of incredulity (SD is normally SO reliable) I realised I could type in the numbers I needed and that worked ok.  I had similar problems when I wanted to delay my resulting flight plan - adjusting the departure time through the "Manage my flight plan" facility caused similar crashes and I ended up having to delete the flight plan and create a new one.
This activity was on a Samsung S22Ultra.  With Android 15.  A significant point is the phone had just updated to One UI version 15.
