Dropping a Pin or Marker while flying.
RV12Flyer
RV12Flyer
Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)
Posts: 11, Visits: 167
May I ask when flying using Skydemon is there a way to quickly drop a pin or waypoint marker over an interesting spot that you are flying over?
Similar to the MOB function (man over board) on other GPS products.
Eg. Quickly marking a spot that you may like to return to.
Thank you
Tony
Press and hold anywhere on the chart (where there isn't already a waypoint) and you can create a user waypoint at that position.
Fliy
F
Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)Too Much Forum (73 reputation)
Posts: 11, Visits: 48
Tim Dawson - 2/6/2023 10:37:54 AM
The "problem" you cannot decide the size of the waypoint. Eg. if you want have a big mark to see it very clearly or rather a small one ...
RV12Flyer
RV12Flyer
Fliy - 2/6/2023 1:57:00 PM
You could create for example 3 red flags (waypoints) around your point so it is easily visible on your Skydemon chart.
You could choose your own icon and number of icons to suit. Also you could add a waypoint in the middle to navigate to or include in your Nav.
Screenshot (1).jpg (364 views, 12.00 KB)
