Dropping a Pin or Marker while flying.
RV12Flyer
RV12Flyer
Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)Too Much Forum (114 reputation)
Posts: 11, Visits: 167
May I ask when flying using Skydemon is there a way to quickly drop a pin or waypoint marker over an interesting spot that you are flying over?
Similar to the MOB function (man over board) on other GPS products.
Eg. Quickly marking a spot that you may like to return to.
Thank you
Tony
Posts: 601, Visits: 29K
A touch on the chart over the position you are interested in will bring up the What’s Here pop-up, on which there is an option to create a User Waypoint.
Try it in simulator mode.
RV12Flyer
RV12Flyer
grahamb - 11/26/2022 2:47:19 PM
A touch on the chart over the position you are interested in will bring up the What’s Here pop-up, on which there is an option to create a User Waypoint. Try it in simulator mode.
Thanks Graham.
I have now found a quick way to mark my current location by tapping the Skydemon Logo top left on Android Mobile.
It then gives the option to 'Create User Waypoint Here'.
The waypoint is named Waypoint 1 and additional waypoints are Waypoint 2 etc.
By doing this it marks what is at your location rather than touching a place on the chart.
Later on after landing you can edit and rename these Waypoints and choose your own icon.
Both methods create a user Waypoint one is directly at your current location and the other wherever you put your finger on the chart.
Thanks again for the reply
Tony
