Entering a raw lat/lon position
G2
G2
Posts: 14, Visits: 85
Hi everybody,
It says in the SkyDemon Mobile Documentation ('Planing a Route' section) that "TIP: You can also enter a raw lat/lon position in standard degrees, minutes and seconds or degrees and decimal minutes format". I am however unable to figure out how to do this. No matter what I type into the 'FIND WAYPOINT' text field, SD Mobile just does not respond to it and I cannot find any other place where to enter position coordinates directly. Is this functionality disabled in SD Mobile version 2.1.1 which I am currently using, or am I doing something wrong? If it is enabled, how and where exactly does one enter the raw waypoint coordinates?
This is an important feature for helicopter pilots, as we obviously can land just about anywhere and so quite often raw position coordinates of a landing site is all we have.
Ivan
Roger.Wilco
Roger.Wilco
Posts: 19, Visits: 273
If you register for a google account and you log-in, in google maps you may add the "LatLng Tool Tip" plugin in the options->MapsLabs menu.
Enrico
R 44 II from Italy
