Entering a raw lat/lon position
http://forums.skydemon.aero/Topic3533.aspx
By G2 - 7/9/2011 7:30:58 AM
Hi everybody,
It says in the SkyDemon Mobile Documentation ('Planing a Route' section) that "TIP: You can also enter a raw lat/lon position in standard degrees, minutes and seconds or degrees and decimal minutes format". I am however unable to figure out how to do this. No matter what I type into the 'FIND WAYPOINT' text field, SD Mobile just does not respond to it and I cannot find any other place where to enter position coordinates directly. Is this functionality disabled in SD Mobile version 2.1.1 which I am currently using, or am I doing something wrong? If it is enabled, how and where exactly does one enter the raw waypoint coordinates?
This is an important feature for helicopter pilots, as we obviously can land just about anywhere and so quite often raw position coordinates of a landing site is all we have.
Ivan
By G2 - 7/18/2011 7:33:36 PM
Thank you Tim! Much appreciated. BigGrin I will try it out on my return from holidays next week.
Best Regards,
Ivan
