Finger Friendly SIP
stevelup
stevelup
Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)Too Much Forum (73K reputation)
Group: Moderators
Posts: 593, Visits: 4.9K
Hi
I've built a new virtual machine into which I have installed the Windows CE 5.0 Standard SDK and nothing else (so there's no possibility of any weird cross contamination happening!).
Please try this DLL.
stevelup
stevelup
Group: Moderators
I believe I have cracked the issue where the keyboard does not work on Windows CE 5.0 devices.
Please grab the dll again from here.
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Thanks Steve,
Can now confirm that the latest skysip480.dll is working correctly on all threee of my 480 x 272 GPS units.
(Two WinCE 5 & one WinCE 6)
Regards,
Max.
stevelup
stevelup
Group: Moderators
Great!
It was a bug in Microsoft Visual Studio. For anyone who's interested, when you change the target of a project, the IDE automatically changes most of the settings, but doesn't update the 'Subsystem' value.
So you end up with a DLL built and linked correctly against the right SDK, but with the Subsystem set at the old value. So in this case, the DLL had a Subsystem of 5.1 which was 0.1 higher than WinCE 5.0 is happy with...
Runways
Runways
Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)Too Much Forum (38K reputation)
Posts: 309, Visits: 1.6K
Can I ask Stevelup if the new WinCE5.0 compatible keyboard is indeed compatible with all subsequent WinCE releases? Welldone again.
Very Newbytheway
DurhamTeaseAirport
stevelup
stevelup
Group: Moderators
Yes, it works fine on CE 6.0.
If anyone needs the 800x480 version recompiling for CE 5.0, let me know.
Jakob
Jakob
Posts: 28, Visits: 1.6K
stevelup (01/07/2011)
YES!
It works on my device now! Thank you Steve!
The autoselectsip does not work, so I have to set it manually, and the taskbar hiding does not make SD use full screen. Unchecking the 'always on top' for the taskbar make it work. I will have to modify the script a bit.
Microlight pilot from Sweden
KevPilot
KevPilot
Posts: 44, Visits: 107
Great work!
I wold love a 800*480 version of this for wince5.0!
kevin
stevelup
stevelup
Group: Moderators
OK, I'll try and do it tomorrow.
stevelup
stevelup
Group: Moderators
It's done.
Grab the DLL from here.
This is all getting a bit messy now. When I get five minutes spare, I'm going to delete all these various files off my server and replace them with a single zip file containing the scripts, the regsvr tool, the AutoSIP tool and the two DLL's.
There is no point in distributing the WinCE 6.0 version of these files any more as this later version runs fine on both platforms.
Steve
