FMCs
MikeE
M
Posts: 3, Visits: 0
Went for a bimble the other day and decided to fly round Gatwick. I looked on SkyDemon for the squawk code but couldn't find it. It did pop up once in the list but disappeared before I could enter it. Farnborough squawk was there, but not Gatwick. Is there a straightforward way of accessing squawk codes and associated listening frequencies in SD?
Apologies if this has been asked before but couldn't find it using the search function
Best wishes
MikeE
M
Posts: 3, Visits: 0
That's an idea, use the airfields tab. Many thanks, folks
Best wishes
Posts: 615, Visits: 30K
MikeE - 11/10/2021 4:11:38 PM
Best wishes
You could download the ENR 6.80 page(s) as a PDF and save it as a user document - available in two touches from the airfields tab (although you'd have to make sure you kept it up to date.)
Alternatively, when you are doing a bimble just plan a route as a 'fly within xnm from' circle and then any relevant FMCs will show up on the Radio tab.
