FMCs
http://forums.skydemon.aero/Topic34218.aspx
By MikeE - 11/9/2021 9:39:37 AM
Went for a bimble the other day and decided to fly round Gatwick. I looked on SkyDemon for the squawk code but couldn't find it. It did pop up once in the list but disappeared before I could enter it. Farnborough squawk was there, but not Gatwick. Is there a straightforward way of accessing squawk codes and associated listening frequencies in SD?
Apologies if this has been asked before but couldn't find it using the search function
Best wishes
By grahamb - 11/10/2021 4:37:16 PM
MikeE - 11/10/2021 4:11:38 PM
That's an idea, use the airfields tab. Many thanks, folks
Best wishes
You could download the ENR 6.80 page(s) as a PDF and save it as a user document - available in two touches from the airfields tab (although you'd have to make sure you kept it up to date.)
Alternatively, when you are doing a bimble just plan a route as a 'fly within xnm from' circle and then any relevant FMCs will show up on the Radio tab.
