Fuel planning on an multiple stop trip WITHIN one tank filling
flyinghuebi
f
Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)Too Much Forum (52 reputation)
Posts: 5, Visits: 9
Hi out there. I read a lot in this forum about fuel planning in SD. Even the pros and cons of making a whole new fuel calculation each stop I plan (with the "land here" function) vs. calculating with the remaining fuel.
BTW, I also plead for a fuel calculation possibility for the whole trip. With calclulate on base of remaining fuel (if you need more votes for that Wink)!
But I found so far no answer for a mostly common problem we have (expect of "do it manually"):
- I recently plan a trip of about 2 hours flight time. That is absolutely within my tank capacity WHITOUT any refuelling including reserves.
- The trip has four stops (or more. But even with one stop the problem exists)
- At each leg I get a fuel calculation by SD including the 30 min. holding.
This makes about 120 minutes of holdings/reserve on a 120 minute flight with 4 stops. That does really not make sense!
Altough I do understand why you (until now Wink) decided not to implement a feature that calculates the fuel based on the remaining amout after first landing, I cannot find a way to tell SD "please use the 30 Min. Holding and contingency JUST ONCE".
Is there a way to do so which I simply not found?
It is absolutely clear that I can plan a flight without "land here" and ad manually the amount of fuel for landing and departure/take off. But that is IMHO much more critical and error-prone, than computing with the reamining fuel I think.
A suggestion for that often discussed topic could be: In the settings offer a checkbox which says "Plan or do not plan reserve/holding/contingency after each landing". If you want add "we highly recommend to leave this active". Or an explanation "If you turn this to off reserve/holding/contingency fuel will be calculates just once for the whole trip".
But the - in my opinion -  best solution is the here in the forum often suggested way to calculate a multiple stop (or sector) with the remaining fuel and send a warning when there is not enough fuel for further legs.
Thank for your suggestions on my question above, hints and answers
Daniel
"If you know where you are you can be wherever you want..."
Posts: 361, Visits: 2.6K
Daniel,
I think you may be asking for far too much added complexity to simple fuel planning.
I too fly an aircraft with only a single 49 litre fuel tank. I know my fuel consumption, averaged over many hours of flying, to be around 16.5 litre/s per hour.
I feel comfortable knowing a single flight of, say, 2hrs duration will leave me with about 45 - 55 mins reserve before only fumes left in tank.
Taking into account that some fuel will be unusable I will start to feel uncomfortable about flying for longer that 2 hrs 15 mins.
So, I know not to fly for more than 2 hrs 15 mins thereby giving me around 30 mins maximum reserve, assuming my fuel tank was completely full.
I also carry with me a calibrated dip stick so I know exactly how much fuel I have left in my tank...
Sometimes it is best to go back to basic, manual, flight planning for some safety critical elements, such as fuel planning.
Tony
