Traffic warning, aircraft following, towing gliders
Blaufranky
B
Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)
Posts: 5, Visits: 4
Dear all,
I am using SkyDemon with SkyEcho II, FLARM-license and iPhone as a traffic screen and I could not be happier with this setup. Works like a charm. Thank you very much.
There is only one issue that I like to report for consideration:
I am flying the tow-aircraft in a glider club and with SkyEcho II + FLARM I get a much better overview on where all these gliders are.
But the glider behind the tow aircraft is generating multiple traffic warnings like "glider behind, following, same level".
I do not want to silence these warnings, because the glider will soon be released and becomes a potential thread.
Is there a work around for this issue, that I have not found so far.
Or can it be considered not to warn, if a target is following constantly on "almost same distance and same level" or from ground onwards.
Or more in general: an aircraft behind the own aircraft should not be a potential thread unless it gets into the half-sphere from approximately 90° ... 150° right to left or has much higher speed so that it obviously caches up.
Thank you again and very best regards
Frank
efrenken
efrenken
Posts: 265, Visits: 3.5K
In the radar window tap on the glider you are towing and you’ll be presented a menu which gives you the opportunity to ignore all a/c or specific a/c.
After the glider has been released do the same procedure to ‘un-ignore’ it.
Best
Eric
Blaufranky
B
Posts: 5, Visits: 4
Yes, ok, this method with "ignore / unignore" would work, but it is much to much head downtime in critical phases of flight.
My point was: aircraft following the own aircraft on constant distance should not cause multiple warnings. These warnings bother and dilute other warnings, that are really critical.
Posts: 8.2K, Visits: 9.5K
It would be dangerous for us to try to establish what another aircraft is doing and selectively ignore it if we think you're towing it.
As Eric said, the solution is to opt to silence warnings for it. You might even be able to do this while you're still on the ground, I'm not sure.
Blaufranky
B
Posts: 5, Visits: 4
Tim Dawson - 4/16/2021 9:08:02 AM
If my memory is correct, on the ground, there is no indicated traffic that can be "silenced" ... but I will try next time.
I understand the opinion with "selective ignore" ... but seriously: warnings every 20 seconds because a known thread is following and diluting possible other warnings is dangerous either.
Raphael_A
R
Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)Too Much Forum (113 reputation)
Posts: 11, Visits: 0
When connected to Skyecho: is SD using the GPS data of Skyecho or the GPS of the iPad/iPhone?
Raphael_A - 4/17/2021 3:09:01 PM
When connected to SkyEcho SD uses SkyEcho as its GPS data source.
6332, SD 4.1.2
Hamish Mead
Hamish Mead
Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)Too Much Forum (223 reputation)
Posts: 19, Visits: 97
Tim,
I appreciate the 'selectively ignore it if we think you're towing it' approach would be dangerous.
Instead, might it be possible to implement a 'selectively silenced until beyond range' approach?
Here's how it might operate:
SD continues to silently monitor a glider under tow for which alerts have been selectively silenced by the tug pilot,
Reversion to normal alerting is automatically triggered when the glider releases, by the combined logic:
- Cessation of the (silenced) alerts AND
- The glider exceeding some distance from the tug beyond the length of the tow rope – such an additional test may be necessary for the logic of the first test alone to not result in a false negative; say when a glider is still under tow and performs boxing manoeuvres. (Apologies if I'm talking bollocks - my understanding of FLARM's full capabilities is limited.)
If it could be made to work, it would mitigate the two safety concerns @Blaufranky raised:
- The need to go 'heads-down' in order to manually un-ignore alerts following glider release, and
- The distracting nature of the nuisance alerts of an otherwise known threat.
As an ex-tuggy I can fully see Blaufranky's concerns.
Yes, that could work. It would still require the tug pilot to manually silence the alerts in the first instance, though. Something like "Silence Until Parted" or similar.
Hamish Mead
Hamish Mead
Tim Dawson - 5/10/2021 9:47:48 AM
Sounds perfect Tim!
Thinking about it, could be useful for formation flying too.
