I wanted to come back to this subject after more testing.
First of all, I love my SkyDemon and my SkyEcho and I am more than happy that I invested into this combination. SkyDemon has done a great job to integrate the two systems.
But when using SkyDemon + SkyEcho + Flarm during glider towing (or more general, in an area with high Flarm traffic), the development should go some more steps.
Yesterday I made about 30 tow-flights on an airfield with a lot of Flarm traffic.
The tug-aircraft is equipped with its own Flarm traffic monitor and I added my SkyDemon + SkyEcho for three reasons:
a) much better traffic screen on the iPhone.
b) ADS-B-In
c) verbal traffic warning
During all the flights the Flarm traffic monitor did not issue a single warning ... simply because no other plane came in front of me.
But the SkyDemon verbal traffic warning was TALKING ALL THE TIME:
1.) "Warning: Glider behind, same level" - yes known when you tow, why bother, its behind ... and why do you repeat every 20 sec.?
2.) "Warning: Glider behind, overtaking 10 km / h" - really, how does the glider do that and how does SkyDemon generate such an exact speed calculation ?
3.) "Warning: glider ahead, 100 ft below" - yes ok, but it is on the ground, in the hangar and not moving.
4.) "Warning: glider, 400 ft below, same heading" - yes, I see it on the ground, they are pulling it back to the departure point with a car.
I repeat - Flarm was silent all the time, no single warning.
I was really surprise to experience such a major difference in behaviour.
I accept that towing gliders might not be the number one use-case for SkyDemon.
SkyDemon is ahead of competition when it comes to Flarm integration into VFR Navigation software.
But Flarm by definition brings more glider-specific issues with itself, like tug-aircraft, like many stations on the ground close to each other, that want to be adressed.
Obviously Flarm has solved most of these issues and it would be very helpful if Skydemon solves some of the above topic over the time.
Thank you again
F.
P.S. I tried the silencing button as discussed last time, but most of the flight have a duration of 5 min. ... and when the tug lands, the next gliders waits. There is simply no time to select / deselect certain gliders for silencing ... and all / many of them are named "Flarm" ... you simply don't know, which one you want to silence when they sit on the ground close to each other.
