Colour and size of traffic
piperpa28
Posts: 14, Visits: 4
Hi
‌I'am using latest SD with Stratux as FLARM device on an iPad mini and can see all traffic around me. But the icons of the planes are in white and a little bit too small. It would be nice to have the possibility to change these settings like the icon of the chosen icon for the type of aircraft itself.
‌Thanks you in advance.
‌Kind regards
‌Stefan
Edited 1/13/2017 12:38:28 AM by piperpa28
Maverix
M
Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)Too Much Forum (619 reputation)
Posts: 53, Visits: 14
I also would prefer a customizable size for the text next to targets and bearingless circles.
Peter Robertson
Peter Robertson
Posts: 48, Visits: 140
@Maverix
As per my post above, you can already vary the text size of the traffic details between 50% and 150% of the default.
Maverix
M
Peter Robertson - 3/5/2021 10:04:14 PM
@MaverixAs per my post above, you can already vary the text size of the traffic details between 50% and 150% of the default.
Thanks for your reply.
But only the text size for all details and not specific for the traffic details, right?
Peter Robertson
Peter Robertson
@Maverix
True, but if you need the traffic text larger (or smaller) surely the same applies to all the other text as well?
As I get ever older and need stronger glasses for close work, I can see less and less need for a reduction from the default (which I have never used) and could certainly make a valid case for a greater text size increase than 150%, though we need to be careful not to get to the situation where it obstructs essential detail on the chart below. Perhaps a modest tweak to text size to allow a range of say 75% to 175% of default would be a sensible and reasonable solution. Thoughts everyone....
Best Regards
Peter
Maverix
M
Peter Robertson - 3/6/2021 7:34:30 AM
@MaverixTrue, but if you need the traffic text larger (or smaller) surely the same applies to all the other text as well?As I get ever older and need stronger glasses for close work, I can see less and less need for a reduction from the default (which I have never used) and could certainly make a valid case for a greater text size increase than 150%, though we need to be careful not to get to the situation where it obstructs essential detail on the chart below. Perhaps a modest tweak to text size to allow a range of say 75% to 175% of default would be a sensible and reasonable solution. Thoughts everyone....Best RegardsPeter
For me it is much more important to see the level of the foreign targets than the name of the city I am flying over....
piperpa28 - 1/13/2017 12:38:28 AM
piperpa28 - 1/13/2017 10:00:40 AM
Tim Dawson - 1/13/2017 10:46:05 AM
TouchTheSky - 1/15/2017 2:07:06 PM
T67M - 1/13/2017 4:46:07 PM
Sfera72 - 2/21/2021 8:27:59 AM
Fliegerpeer - 2/22/2021 3:00:12 PM
efrenken - 2/22/2021 8:03:27 PM
pilot-byom - 2/23/2021 11:02:30 AM
C401 - 2/24/2021 12:46:38 AM
Exfirepro - 2/26/2021 1:22:16 PM
DarkStar - 2/28/2021 6:54:30 PM
Tim Dawson - 3/1/2021 10:07:19 AM
Maverix - 3/5/2021 8:48:41 PM
Exfirepro - 3/5/2021 10:04:14 PM
Maverix - 3/6/2021 6:59:22 AM
Exfirepro - 3/6/2021 7:34:30 AM
                         For me it is much more important to see the level of the foreign...
Maverix - 3/6/2021 7:44:30 AM
checksix - 3/11/2021 10:54:21 AM
Exfirepro - 3/11/2021 4:44:36 PM
checksix - 3/11/2021 7:17:01 PM
Maverix - 3/26/2021 6:11:15 AM
efrenken - 4/18/2021 12:46:33 AM
