Finger Friendly SIP
Roger.Wilco
Roger.Wilco
Posts: 19, Visits: 273
Stevelup: no need to be sorry. You've done a fabulous job.
For your info: downloaded the latest version and it works perfectly.
Thanks once more,
Enrico
R 44 II from Italy
Runways
Runways
Posts: 309, Visits: 1.6K
Yes, a job well done again, Steve. Thanks.
Very Newbytheway
DurhamTeaseAirport
Edited 6/4/2011 5:00:40 PM by Runways
Jakob
Jakob
Posts: 28, Visits: 1.6K
stevelup (31/05/2011)
Hi
No idea if this will help. Can someone with a WinCE 5.0 device try this DLL instead?
Hi, I tried it on my device. Not working Sad
Using a little tool called executabilitycheck it tells me it doesn't match CPU type (I have a Samsung ARM920T-S3C2443) and it requires OS version 5.1. OS version of this machine is 5.0
Microlight pilot from Sweden
stevelup
stevelup
Group: Moderators
Posts: 593, Visits: 4.9K
Hmm... It's definitely for the correct CPU the issue must be with the OS version.
Exactly where is it failing?
Jakob
Jakob
Hi Steve,
It is just a tool for checking dependencies. It can override/overwrite the OS version required by the DLL. If I do that I can successfully register the DLL with regsrvce, and "SkyDemon480" appears in the list of input panels, but it does not work. "The selected input method could not be loaded."
Are you sure you built it for CE 5.0?
stevelup
stevelup
Group: Moderators
The only SDK's I have is Windows Mobile 5.0 and Windows CE 6.0.
It looks like I need to get hold of the Windows CE 5.0 SDK.
I'll investigate.
screetch82
screetch82
Posts: 123, Visits: 176
hi
cool gadget. I tried on my navsgo wince 5.0 and also get same error thrown up that it failed to register.
I edited the mscr file and pointed it to the 50 dll, but this made no improvement. After each try i had
to reboot the device. Problem with navsgo is, that you cant get to the windows screen, but only
select particular files and programms you wish to start from the inhouse menu software.
stevelup
stevelup
Group: Moderators
OK, if someone wants to send me a WinCE 5.0 device, I'll try and get it working.
I can't really do figure it out without a unit in my hand.
The last DLL I uploaded was built against WinCE 5.0 and ran OK in the device emulator.
Jakob
Jakob
stevelup (12/06/2011)
Any progress on this?
Steve, just to make sure, did you really build it against CE 5.0 and not Win Mobile 5.0? Those are different things...
stevelup
stevelup
Group: Moderators
The first one was built against Windows CE 5.0, the second against Windows Mobile 5.0.
As I said, if someone wants to send me a CE 5.0 device, I'm happy to get it working - but no one has taken up that offer yet.
