Maverix
Visits: 14
since a few weeks I'm using Skydemon and I'm very happy with it. Thanks for that great software.
Yesterday I ordered Pilotaware and now I'm looking forward trying this hardware together with Skydemon.
I thought about building up an OGN-R ground station for the FLARM functionality but after mailing with Keith from Pilotaware it seems that my location is not the best because of buildings around my garden.
Now I'm wondering why Skydemon doesn't fetch the glider positions from the OGN via LTE/mobile data? My tablet has LTE and should be able to connect the OGN during flight.
Maybe you can explain to me why it's not possible?
Thanks in advance.
Cheers Kai
Posts: 8.2K,
Visits: 9.8K
Are you suggesting we attempt to use GSM mobile connectivity in flight in order to provide tactical collision avoidance?
Maverix
Visits: 14
+xAre you suggesting we attempt to use GSM mobile connectivity in flight in order to provide tactical collision avoidance? In UK Pilotaware is using OGN-R to show FLARM traffic. In Germany the OGN-R network is still not common and Pilotaware pilots don't get traffic information from FLARM gliders, ultralights an helicopters. The normal OGN network ist common in Germany. That's why I asked if it would be possible to get the information from OGN network via GSM mobile.
Visits: 388
Commercially re-broadcasting OGN will be a GDPDR nightmare - aircraft registrations are personal data, especially gliders. You (may) get away with operational needs from within the cockpit as long as the data stays at the local device, but collecting on servers and transmitting via mobile networking sounds like from the worst bucket of worms.
Posts: 8.2K,
Visits: 9.8K
I think the privacy concerns would be surmountable because people are broadcasting this data specifically for the purpose of other people avoiding them in the air.
However, tactical collision avoidance using high-latency and unreliable GSM mobile network data is a non-starter. It might work just occasionally enough to give the pilot a false sense of security, which would be a bad thing.
The solution is to properly equip with ADS-B and encourage as many others to do so as possible.
TouchTheSky
Visits: 4.6K
+x+xAre you suggesting we attempt to use GSM mobile connectivity in flight in order to provide tactical collision avoidance? In UK Pilotaware is using OGN-R to show FLARM traffic. In Germany the OGN-R network is still not common and Pilotaware pilots don't get traffic information from FLARM gliders, ultralights an helicopters. The normal OGN network ist common in Germany. That's why I asked if it would be possible to get the information from OGN network via GSM mobile.
Kai, why don't you built your own Stratux based on the Stratux Europe version? It supports ADS-B and FLARM at a cost of less than € 150,-. At the same time it provides you with a very reliable GPS source, supporting GPS, GLONASS and GALILEO ...
Maverix
Visits: 14
+x+x+xAre you suggesting we attempt to use GSM mobile connectivity in flight in order to provide tactical collision avoidance? In UK Pilotaware is using OGN-R to show FLARM traffic. In Germany the OGN-R network is still not common and Pilotaware pilots don't get traffic information from FLARM gliders, ultralights an helicopters. The normal OGN network ist common in Germany. That's why I asked if it would be possible to get the information from OGN network via GSM mobile.
Kai, why don't you built your own Stratux based on the Stratux Europe version? It supports ADS-B and FLARM at a cost of less than € 150,-. At the same time it provides you with a very reliable GPS source, supporting GPS, GLONASS and GALILEO ... Does Stratux show also bearingless targets from Mode C and Mode S Transponders? Does it work with Skydemon? I can find Stratux at Amazon for 270,- €
Maverix
Visits: 14
+xI think the privacy concerns would be surmountable because people are broadcasting this data specifically for the purpose of other people avoiding them in the air.
The solution is to properly equip with ADS-B and encourage as many others to do so as possible. Okay, understood.
Thanks.
Massimo Belloni
Visits: 6.5K
+x+x+x+xAre you suggesting we attempt to use GSM mobile connectivity in flight in order to provide tactical collision avoidance? In UK Pilotaware is using OGN-R to show FLARM traffic. In Germany the OGN-R network is still not common and Pilotaware pilots don't get traffic information from FLARM gliders, ultralights an helicopters. The normal OGN network ist common in Germany. That's why I asked if it would be possible to get the information from OGN network via GSM mobile.
Yes, it works perfectly with Skydemon. I see for sure non ADS/B xpndrs (but, of course, the target bearing is not indicate). You can see some interesting video, specific about Stratux and Skydemon, i.e.: Build one is really very, very simple, you can buy on Amazon the single parts and assemble them without solder anything. Just remember to get also the AHRS module (which usually is indicated as optional)., because without it it won't work correctly.
Have fun!
Massimo Belloni
Maverix
Visits: 14
I ordered the necessary parts and will give a try 👍
