Track Logs (unable to remove in Android anymore)
Liam Sandie
Liam Sandie
Posts: 72, Visits: 261
Hi all,
Can anyone advise why we are now unable to remove tracklogs we don't wish to upload to the cloud for example (broken ones of short flights we don't want to save). Previously you could swipe to delete any tracklog on the android device and then send all to cloud (and even remove them all from your device, knowing they are safely in the cloud).
As it stands now they seem permanently stuck on the device regardless if you send to cloud or not.
Liam
Liam Sandie
Liam Sandie
Tim Dawson - 9/5/2019 4:23:04 PM
SkyDemon tries to keep your logs in sync, and doesn't expose a way to delete from only your device.
However, a colleague has just mentioned that if you switch SkyDemon to offline mode, then delete from the Open menu, SkyDemon will only delete the local copy as it will be disconnected from the cloud. It won't then delete at some point in the future.
Thanks Tim. You certainly used to be able to delete from the local device prior to sync. Hopefully this feature can be brought back
