Track Logs (unable to remove in Android anymore)
Liam Sandie
Liam Sandie
Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)Too Much Forum (8.9K reputation)
Posts: 72, Visits: 261
Hi all,
Can anyone advise why we are now unable to remove tracklogs we don't wish to upload to the cloud for example (broken ones of short flights we don't want to save). Previously you could swipe to delete any tracklog on the android device and then send all to cloud (and even remove them all from your device, knowing they are safely in the cloud).
As it stands now they seem permanently stuck on the device regardless if you send to cloud or not.
Liam
Posts: 353, Visits: 2.5K
I think it works in this way:
1. Backup all logs to the cloud
2. Click on "All Logs"
3. Select (press and hold) a log you wish to delete. The "Delete" popup should display.
4. Delete the log.
Works for me for some logs I no longer require.
Tony
Liam Sandie
Liam Sandie
tnowak - 8/29/2019 6:44:16 AM
4. Delete the log.
Tony
Thanks Tony.  So that method keeps the ones backed up to cloud?
Liam Sandie
Liam Sandie
4. Delete the log.
Tony
When you click into All Logs you are looking at the Cloud logs so I am back to my original query unfortunately, is there now no way of removing logs from the device only?
