Track up view isn’t quite
Succentor
S
Posts: 2, Visits: 3
New user here...
Both my previous handheld devices (Lowrance and Garmin) in track up mode did precisely that - even the smallest course correction resulted in a small rotation of the map. The ownship icon remained strictly pointing up.
Skydemon appears to implement a 'track nearly up' option instead - resulting in the track being often a few degrees either side of straight ahead - and also in the map only moving periodically to reflect movement along track. I assume this is a design feature to improve performance rather than redraw the map constantly on slower devices.
Is there a way to get a true 'track up' display? If not, I might request it in a future release...
I may, of course, just get used to it!
TouchTheSky
T
Posts: 153, Visits: 4.6K
Succentor - 8/20/2019 10:52:22 AM
New user here... Both my previous handheld devices (Lowrance and Garmin) in track up mode did precisely that - even the smallest course correction resulted in a small rotation of the map. The ownship icon remained strictly pointing up.Skydemon appears to implement a 'track nearly up' option instead - resulting in the track being often a few degrees either side of straight ahead - and also in the map only moving periodically to reflect movement along track. I assume this is a design feature to improve performance rather than redraw the map constantly on slower devices.Is there a way to get a true 'track up' display? If not, I might request it in a future release...I may, of course, just get used to it!
I second this request, sometimes there is almost a 45 degree offset ...
DaveWhite
DaveWhite
Posts: 53, Visits: 205
Choosing 'Course Up' keeps the screen aligned with your planned route, even if you are slightly off track due turbulence or whatever.  Does that help?
Posts: 368, Visits: 2.6K
I have used both "Track Up" and "Course Up" and both seem to work okay for me. Haven't noticed the issues reported by the OP.
My TAS is slow - 75Kt, so don't know whether that is a factor or not.
Tony
SkyDemon only redraws the map once you've changed by X degrees, for performance reasons. It's one of many things we do to make SkyDemon kinder to your battery than other apps. We have no plans to make X configurable; it's never as much as 45 degrees and is actually 15 degrees on modern phones and tablets.
