Track up view isn’t quite
Succentor
S
Posts: 2, Visits: 3
New user here...
Both my previous handheld devices (Lowrance and Garmin) in track up mode did precisely that - even the smallest course correction resulted in a small rotation of the map. The ownship icon remained strictly pointing up.
Skydemon appears to implement a 'track nearly up' option instead - resulting in the track being often a few degrees either side of straight ahead - and also in the map only moving periodically to reflect movement along track. I assume this is a design feature to improve performance rather than redraw the map constantly on slower devices.
Is there a way to get a true 'track up' display? If not, I might request it in a future release...
I may, of course, just get used to it!
Posts: 361, Visits: 2.6K
I have used both "Track Up" and "Course Up" and both seem to work okay for me. Haven't noticed the issues reported by the OP.
My TAS is slow - 75Kt, so don't know whether that is a factor or not.
Tony
