SkyDemon Navigation
In-Flight PilotAware Issues
dave_kent
dave_kent
posted 7/3/2019 12:34:58 PM
HOT
Visits: 2.1K
I've just set up a new PAW device, and have the following questions:
When connected to the PAW device, SD complains it cannot download weather etc. However I have got "Live Date When Planning" ticked, and i'm in navigation mode, so I don't understand why I get that message.
On final approach into Andrewsfield last weekend (for example), the number of audio alerts for traffic on the ground was quite ridiculous and very distracting. Is there a way to filter out traffic on the ground, or even remove all traffic alerts when on final approach?
Dave
Tags
PilotAware
posted 7/8/2019 10:04:38 AM
Posts: 8.3K,
Visits: 10K
Indeed. You've told SkyDemon to use an internet connection but not while flying, and you aren't flying. You're taxiing. Unfortunately the wifi hotspot you're connected to is suggesting to your device that it may offer an internet connection, your device is telling SkyDemon that, and therefore SkyDemon is attempting to use it.
Because this keeps happening, we are changing the behaviour in 3.12.8 and future versions, so that SkyDemon will not attempt to use the internet in such a situation.
dave_kent
Hi Dave ad 1) For live weather you need to access the Internet in-...
TimT
7/4/2019 10:19:56 AM
Hi Tim, #1 - The problem I am having is that SD is trying to get...
dave_kent
7/4/2019 11:57:12 AM
Tapping on my Android tablet does not bring up any options to "mute...
dave_kent
7/15/2019 12:33:33 PM
Is it actually trying to get the weather in flight? Or is it just when...
7/5/2019 11:11:20 AM
The latter Tim - I often get errors prior to hitting "Go Flying", but...
dave_kent
7/5/2019 12:36:15 PM
It happened again today Tim - only on the ground, but several times...
dave_kent
7/6/2019 3:10:24 PM
Indeed. You've told SkyDemon to use an internet connection but not...
You can use Bluetooth tethering for the internet connection (to an...
SimonD
9/15/2020 8:43:59 PM
Dave, you have to tap on the traffic radar instrument.
9/16/2020 9:55:18 AM
I've found a way around this for my Android 9 tablet so that I could...
Alan999
9/16/2020 8:17:43 PM
Wow that was a blast from the past! I've not tried the bluetooth...
dave_kent
9/16/2020 1:18:53 PM
Yes, it will. Your cellular tablet computer will connect to the...
TimT
9/16/2020 3:23:34 PM
