ZorgroZ
Visits: 48
+x+x+x+xThe problem is unfortunately still present under Android with the current version of SkyDemon (3.12.7.22564). I've tested on four devices now: * Motorola G5 Plus * Motorola G7 Plus * Kindle Fire HD 8 * Kindle Fire HD 10
I've tried various settings in both Stratux and SkyDemon. Whenever SkyDemon is connected to the Stratux wifi, it freezes. On iOS everything works as expected.
I'm quite desperate to get this working for safety reasons. Tim / SkyDemon support, would you be able to look into this please? I had a quite lengthy discussion with their support until they finally admitted it was a bug in SD. Anyway, you have two options: OR
2) Install the latest SD beta for Android, where they have fixed the issue properly: Thanks b3nn0. I just tried the latest version of your European Stratux release, but the problem is still there, on both my Kindle Fire HD 8 and my Motorola Moto G7 Plus.
(I didn't see a configuration setting for "SkyDemon Android disconnect bug workaround", so I changed /etc/stratux.conf directly, setting the corresponding variable to "true". That should be ok, right?
Will now try the latest SkyDemon beta and report back. Combination of latest SkyDemon beta and your latest Stratux image seems to work on both Kindle Fire HD8 and Motorola Moto G7 Plus. No freezes observed in more than ten minutes.
Will do a test flight tomorrow and let you know if any further issues. Reporting no issues in 3.5 hours of flight. Tried both my Motorola Moto G7 Plus and my Kindle Fire HD8.
The Stratux saw both ADS-B and Flarm signals.
Thanks b3nn0 for your great work on the European Stratux image (I hope you will continue maintaining it), and to SkyDemon for fixing this long-standing issue!
ZorgroZ
Visits: 48
ZorgroZ
Visits: 48
b3nn0
Visits: 3.4K
ZorgroZ
Visits: 48
b3nn0
Visits: 3.4K
Did that - also happens in the latest beta, by the way.
Posts: 7.8K,
Visits: 8.5K
You might like to contact our technical support about this. I have no knowledge of it but I do know we haven't changed our network connectivity on Android lately.
b3nn0
Visits: 3.4K
Sorry for the double post - any official news on this? It is really quite annoying.. I have used the report functionality of the "App not responding" dialog - no idea if it helps. (EDIT: I'm a full-time Android developer, even though Java, not C#. If I can do anything to help, let me know)
b3nn0
Visits: 3.4K
Seeing the same issue. But I'm pretty sure that this is not a stratux bug. It also happens with other devices (as OP said, iLevil. And - no matter what stratux does, crashing is certainly not the right way to deal with it). And yes, it is clearly related to network usage by skydemon. Somehow Skydemon seems to block the main thread while waiting for network i/o (until it times out eventually). This is definitely a skydemon issue. Also, it seems to be a rather new issue. I think I didn't have that problem in older Skydemon versions. Basically, whenever the Android devices is connected to a Wifi without internet connection and Skydemon is set to use data, it will freeze occasionally.
neubamat
Visits: 18
This happens to me with SD 3.12.4.27411 on Fire Tab HD 8 as well. I wasn't able to reproduce it with my Nokia 6 (Android P) even if just wifi was enabled (mobile data offline). If I connect to a non routable wifi network, I'm getting a network connection error notification on Nokia 6 and no dialog but a lock up on HD 8.
That's my workaround: connect tab to wifi with internet connectivity and "Internet Usage" set so "Live Data when Planning" to download recent data. - set SD to "Offline Mode", exit SD
- connect to stratux
- launch SD
I didn't see any crashes when following this procedure.
