SkyDemon freezes or crashes when connected to WiFi
ZorgroZ
ZorgroZ
Posts: 23, Visits: 48
SkyDemon locks up periodically (or even crashes) when my device is connected to one of the on-board Wi-Fi networks of my plane:
* Stratux (versions 1.5b1 and 1.5b2)
* iLevil AHRS Mini
After a few seconds, SkyDemon becomes unresponsive or crashes. This happens regardless whether in planning or navigation mode (doesn't matter if I have third-party device enabled in settings or not).
SkyDemon is able to connect to my Stratux and receive GPS position and traffic, but alas only for a few seconds before it locks up or crashes.
I have tried SkyDemon on Android on the following devices: Moto G5 Plus, Amazon Kindle HD Fire 8 and 10. I have tried different recent SkyDemon versions (latest stable 3.11.2, and beta 3.11.3.26929). I have tried different SkyDemon settings, and cleared the application cache of SkyDemon.
SkyDemon does not have this issue when the device is connected to a regular wifi of my home. So I'm suspecting that the messages that those wifi devices are sending (GDL90, NMEA) are throwing off SkyDemon for some reason.
Do you have any ideas what could cause this, and how I can further diagnose the issue?
b3nn0
b
Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)Too Much Forum (486 reputation)
Posts: 42, Visits: 3.4K
ZorgroZ - 6/15/2019 5:04:24 PM
The problem is unfortunately still present under Android with the current version of SkyDemon (3.12.7.22564). I've tested on four devices now:
* Motorola G5 Plus
* Motorola G7 Plus
* Kindle Fire HD 8
* Kindle Fire HD 10
I've tried various settings in both Stratux and SkyDemon. Whenever SkyDemon is connected to the Stratux wifi, it freezes. On iOS everything works as expected.
I'm quite desperate to get this working for safety reasons. Tim / SkyDemon support, would you be able to look into this please?
I had a quite lengthy discussion with their support until they finally admitted it was a bug in SD.
Anyway, you have two options:
1) Install the latest Stratux European Edition image on your Stratux, which contains a workaround (it configures Android's network interface slightly different): https://github.com/b3nn0/stratux/releases
OR
2) Install the latest SD beta for Android, where they have fixed the issue properly:
ZorgroZ
ZorgroZ
b3nn0 - 6/15/2019 6:04:39 PM
* Motorola G5 Plus
* Motorola G7 Plus
* Kindle Fire HD 8
* Kindle Fire HD 10
OR
Thanks b3nn0. I just tried the latest version of your European Stratux release, but the problem is still there, on both my Kindle Fire HD 8 and my Motorola Moto G7 Plus.
 (I didn't see a configuration setting for "SkyDemon Android disconnect bug workaround", so I changed /etc/stratux.conf directly, setting the corresponding variable to "true". That should be ok, right?
Will now try the latest SkyDemon beta and report back.
ZorgroZ
ZorgroZ
ZorgroZ - 6/15/2019 7:58:43 PM
* Motorola G5 Plus
* Motorola G7 Plus
* Kindle Fire HD 8
* Kindle Fire HD 10
OR
Combination of latest SkyDemon beta and your latest Stratux image seems to work on both Kindle Fire HD8 and Motorola Moto G7 Plus. No freezes observed in more than ten minutes.
Will do a test flight tomorrow and let you know if any further issues.
Edited 6/15/2019 8:24:42 PM by ZorgroZ
ZorgroZ
ZorgroZ
ZorgroZ - 6/15/2019 8:24:02 PM
* Motorola G5 Plus
* Motorola G7 Plus
* Kindle Fire HD 8
* Kindle Fire HD 10
OR
Reporting no issues in 3.5 hours of flight. Tried both my Motorola Moto G7 Plus and my Kindle Fire HD8.
The Stratux saw both ADS-B and Flarm signals.
Thanks b3nn0 for your great work on the European Stratux image (I hope you will continue maintaining it), and to SkyDemon for fixing this long-standing issue!
Edited 6/17/2019 8:45:29 PM by ZorgroZ
ZorgroZ - 2/19/2019 10:21:14 AM
pilot-byom - 2/19/2019 11:39:59 AM
ZorgroZ - 2/19/2019 12:20:23 PM
pilot-byom - 2/19/2019 12:57:17 PM
ZorgroZ - 2/19/2019 12:58:55 PM
ZorgroZ - 2/19/2019 7:29:08 PM
neubamat - 3/23/2019 11:06:40 AM
b3nn0 - 4/16/2019 2:14:39 PM
b3nn0 - 4/30/2019 12:20:00 PM
Tim Dawson - 5/1/2019 10:06:06 AM
b3nn0 - 5/1/2019 11:53:08 AM
                         Reporting no issues in 3.5 hours of flight. Tried both my Motorola...
ZorgroZ - 6/17/2019 8:44:45 PM
