+x Mazsola - 3/17/2019 1:18:47 PMWhat I did to try to improve the situation:- checked WIFI status on the tablet: it is on maximum, states outstanding signal. Connected to and sees Skydemon (according to settings menu)- switched the two dynon WIFI dongles between the two Dynon screens- installed skydemon on another tablet (also android) to check any difference in behavior- checked skydemon software status again and then upgraded to march 08 version.And then with this latest software upgrade a completely new and unexpected phenomenon raised:I can start Skydemon but when I touch the "go-fly" button, I got following error message:"Skydemon needs to be given access to your location before it can operate in Go Flying mode"That means, although the wifi connection to Dynon is established (shown in the settings menu) there is no connection to the Dynon modul and the to built in GPS...?I checked this with both of my tablets independently, both times got the same result ! Currently I can not use the dynon GPS at all.Anyone out there with similar experience ?Could this be a problem of the wifi-dongles ? But then, why can I see the established wifi connection in the settings menu of the tablet?Thank you for your feedback !
+x Skyboy999 - 3/20/2019 7:47:30 AM+x Mazsola - 3/17/2019 1:18:47 PMWhat I did to try to improve the situation:- checked WIFI status on the tablet: it is on maximum, states outstanding signal. Connected to and sees Skydemon (according to settings menu)- switched the two dynon WIFI dongles between the two Dynon screens- installed skydemon on another tablet (also android) to check any difference in behavior- checked skydemon software status again and then upgraded to march 08 version.And then with this latest software upgrade a completely new and unexpected phenomenon raised:I can start Skydemon but when I touch the "go-fly" button, I got following error message:"Skydemon needs to be given access to your location before it can operate in Go Flying mode"That means, although the wifi connection to Dynon is established (shown in the settings menu) there is no connection to the Dynon modul and the to built in GPS...?I checked this with both of my tablets independently, both times got the same result ! Currently I can not use the dynon GPS at all.Anyone out there with similar experience ?Could this be a problem of the wifi-dongles ? But then, why can I see the established wifi connection in the settings menu of the tablet?Thank you for your feedback ! Just a thought- you say Dynon is showing moving map
