iOS 12 Supported?
Posts: 8.3K, Visits: 9.8K
aRTy, SkyDemon's IFR features are used by thousands of IFR pilots across Europe. When used with the excellent free route finding and briefing service Autorouter, together they should be all you need.
jollyrog
jollyrog
Posts: 24, Visits: 24
I had this too last night on a night flight.
nkt2000
nkt2000
Posts: 23, Visits: 128
I see there is an update for RunwayHD to solve rendering issues as well. Looks like Apple strikes again🙄
Will hold off updating until Tim’s fix arrives.
aRTy
aRTy
Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)Too Much Forum (173 reputation)
Posts: 3, Visits: 14
Tim Dawson - 10/1/2018 2:05:18 PM
We have found what Apple have broken, and changed SkyDemon so that it uses alternative functionality. No compromise has been made while doing that, and 3.10.5 is now on its way to release. It will suffer no slowdown on iOS 12.
If this works, it is an example of perfect support!
Thank you.
Imagine SD would have the ability for IFR (of course for more money). Forget about ForeFlight...
pilotcgloav
Posts: 1, Visits: 0
Hey Tim,
just tried it with turned off Virtual Radar. Seems to be fixing this issue with iOS12 on an iPad Air 2
plume_tray
plume_tray
Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)Too Much Forum (7.9K reputation)
Posts: 116, Visits: 434
Tim, I noticed Virtual Radar was always the longest to finish loading/updating after interacting with the route/map. But sorry to say I’ve not tried with it turned off yet.
Turning off Virtual Radar when it's got laggy appears to solve the problem. Can anyone else confirm?
We have reproduced the lagging issue on iOS 12. After thoroughly profiling it, we've so far determined the problem is deep within the graphical drawing routines of iOS. As for why it gets worse over time, we have no idea.
My main job today is to perform further instrumentation to determine if there's any way we can temporarily work around it by changing the manner in which we perform certain drawing, however this appears to be a problem with the operating system so it's unclear whether I will be successful and even if I am, it's likely to only be a temporary fix. I will report back tomorrow.
plume_tray
plume_tray
So, been using my older iPad mini 2 (iOS 11.4.1 with SD 3.10.1) for the last 4 days, with long flights and requiring lots of touchscreen interaction inflight.
Although, generally its been performing better than my newer iPad mini 4 (iOS 12.0 with SD 3.10.4) did the weekend before, I have been experiencing freezing and restarts - even on the older iOS. I suspect the restarts / freezing on my older iPad could be due to battery age as iOS 11 introduced CPU throttling when the battery underperforms.
Anyway, I'm now stuck between two evils. I really want to use my newer iPad mini 4 with the faster cpu, but I haven't been able to successfully downgrade to iOS 11.4.1. I have the ipsw file for it but the option key / restore using iTunes on my mac isn't bringing up the file browser. Its always forcing an install of the latest iOS. I've done countless google searches and I understand the instructions, but iTunes isn't playing ball. iTunes/iCloud backups are meaningless, as they don't backup the firmware so be warned.
UPDATE: Re the iTunes restore, I've successfully downgraded to 11.4.1. Turns out the option key isn't recognised over screen sharing (I use a mac mini for all backups and remotely connect to it via my MacBook). Phew!!
Edited 10/1/2018 10:51:48 AM by plume_tray
