iPhone / Route / Share - G1000 - Missing .fpl file
danko
d
Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)Too Much Forum (69 reputation)
Posts: 7, Visits: 4
I am trying to figure out a way to wirelessly transfer SkyDemon route to G1000. For that purpose I have purchased Toshiba FlashAir SD card which allows you to wirelessly transfer files to/from your mobile/tablet device.
My idea is to create a flightplan in SD, go to Route/Share, choose FlashAir app (or FileBrowserGO to save to network drive) and see if the flightplan will be loaded onto the device.
However during the export only two files are created:
- text.txt
- MyRoute.flightplan
Text file mentions that GPX and FPL formats should be saved as well:
"The route is attached in native SkyDemon format, and also in GPX and FPL formats for use with other systems. "
but they are nowhere to be found, my skydemon version is 3.10.4
I have read somewhere that people are successfully transferring routes to G1000 by saving as FPL, so if SD could share .flp then it's basically a done deal and it should be loaded by G1000.
I am not familiar with iOS development and deployment to appstore but I could probably write a small iOS app which would convert the .flightplan to .fpl and transfer to FlashAir if SD is not able to do fpl export/share since I think that this function could be interesting to a lot of users.
I don't think we've had much call to make our .fpl exporter function on the mobile versions of our software, which is why it's currently not included. If we get much call, we would certainly consider it of course.
