rikur
rikur
Posts: 132, Visits: 632
(updated August 2018)
For High Sierra:
Known issues:
How does it work?:
rikur
rikur
Frank de Jong - 8/20/2018 11:38:31 AM
I created a sub-folder in the Application folder and moved the .app file (542/550 MB) to the new folder.
When control clicking + open the app in the new folder I got both security warnings and I allowed for the app to open and for the incoming connections (probably also needed for updates of the charts). The app seems to start (a little black dot appears under the SkyDemon icon in the Dock) and then simply stops, without ever having displayed any of the SD screens.
Something is blocking the app to continue its start-up sequence, but what would that be? I'm puzzled... What settings to check?
sounds like you have done the right things  ....... you're not alone in that others have reported the same, and in a small number of cases remain a mystery.  Any anti-virus or security software running?
one final observation - sometimes it does take a good 3 or 4 minutes for the first load of the application to run.
Sorry I haven't got any more definitive solutions - the problems of relying upon free Wineskin.
rikur - 11/20/2015 9:44:00 PM
Bajab - 11/21/2015 7:19:48 PM
rikur - 11/21/2015 7:25:13 PM
rikur - 11/22/2015 8:57:10 PM
rikur - 11/23/2015 6:34:45 PM
C82R - 11/28/2015 9:23:29 PM
rikur - 11/29/2015 7:52:26 AM
rikur - 11/29/2015 8:53:56 PM
                 hii
                 hii
rikur - 12/2/2015 10:30:52 AM
guille - 12/2/2015 6:12:04 PM
rikur - 12/2/2015 6:13:26 PM
Gernot - 12/6/2015 1:30:12 PM
rikur - 2/4/2016 4:08:08 PM
reimomo - 3/3/2016 7:50:58 PM
reimomo - 3/3/2016 7:52:07 PM
rikur - 5/5/2016 10:41:45 AM
guille - 5/20/2016 7:47:28 AM
rikur - 5/20/2016 8:49:48 PM
guille - 6/2/2016 12:09:59 PM
rikur - 6/2/2016 7:26:25 PM
rikur - 8/2/2016 6:54:12 AM
ADW666 - 9/12/2016 5:15:21 PM
rikur - 9/12/2016 9:18:12 PM
ADW666 - 9/12/2016 9:22:32 PM
                     + x [quote] [b] ADW666 - 9/12/2016 9:22:32 PM [/b] +...
rikur - 9/12/2016 9:49:55 PM
rikur - 9/17/2016 11:22:51 AM
KFL - 10/8/2016 7:21:31 AM
rikur - 10/16/2016 9:56:20 AM
                     + x [quote] [b] Cessnaoui - 10/17/2016 2:45:57 PM [/b]...
rikur - 10/17/2016 2:54:31 PM
     Any new?
rikur - 12/6/2016 1:11:19 PM
rikur - 2/22/2017 1:16:32 PM
on5ap - 2/22/2017 1:49:37 PM
rikur - 3/18/2017 8:52:32 PM
nestor - 4/10/2017 8:49:14 AM
rikur - 4/10/2017 8:53:43 AM
rikur - 4/29/2017 1:51:12 PM
on5ap - 5/1/2017 10:26:57 AM
rikur - 5/1/2017 3:39:14 PM
on5ap - 5/26/2017 10:47:14 AM
IvanS - 5/22/2017 4:36:23 PM
rikur - 6/25/2017 4:31:58 PM
rikur - 6/25/2017 7:25:49 PM
                         Yeah, I see. I've just left it as is, for now. Playing with the DPI...
Miked - 7/18/2017 7:13:41 PM
rikur - 7/18/2017 7:19:15 PM
rikur - 7/21/2017 8:15:47 AM
guille - 7/24/2017 2:11:42 PM
rikur - 7/28/2017 8:46:08 PM
rikur - 7/29/2017 11:13:28 AM
rikur - 7/29/2017 7:07:47 PM
rikur - 7/31/2017 7:41:48 PM
rikur - 7/31/2017 8:35:40 PM
                         That worked...! Don't understand why, though, but anyway. Thanks a lot...
rikur - 9/27/2017 3:43:18 PM
                 ‌I will do the step tonight ... wait & see.
SUBA - 10/28/2017 7:06:08 PM
rikur - 10/31/2017 1:07:58 PM
rikur - 10/31/2017 1:22:28 PM
rikur - 12/23/2017 6:51:35 PM
OmeRon - 1/2/2018 1:14:16 PM
rikur - 1/4/2018 10:27:21 PM
             Some suggestions in this thread:...
rikur - 2/21/2018 10:11:26 AM
                 Much appreciated! Working now. ‌ ‌ ‌
ADW666 - 2/21/2018 2:31:50 PM
rikur - 3/17/2018 8:41:50 PM
rikur - 5/25/2018 7:56:17 PM
rikur - 5/26/2018 11:49:59 AM
TJ - 6/30/2018 3:40:11 PM
rikur - 8/7/2018 7:11:36 PM
                 10.13.6
rikur - 8/12/2018 12:16:14 PM
rikur - 8/12/2018 12:28:48 PM
rikur - 8/20/2018 7:30:04 AM
rikur - 8/20/2018 11:15:55 AM
rikur - 8/20/2018 11:43:32 AM
rikur - 8/21/2018 1:52:29 PM
jryam - 9/14/2018 11:06:12 AM
rikur - 9/20/2018 7:37:29 PM
jryam - 9/21/2018 11:04:25 AM
gratd - 9/20/2018 4:23:22 PM
rikur - 10/6/2018 6:38:02 PM
JWB - 12/20/2018 2:12:24 PM
rikur - 12/20/2018 2:40:19 PM
rikur - 3/1/2019 8:31:02 AM
rikur - 3/8/2019 8:27:22 AM
                         I wouldn't estimate that due to Apple Rumors, making ipad apps running...
rikur - 3/25/2019 9:31:40 AM
rk19 - 3/27/2019 3:15:59 PM
gratd - 4/2/2019 10:19:19 AM
guille - 4/3/2019 10:33:03 AM
guille - 4/8/2019 4:38:35 PM
gratd - 4/30/2019 8:26:26 AM
rikur - 5/10/2019 8:33:41 AM
                         Fine! Same, as said, for näme. Really NO troubles at all. Even the...
                 Good news ! Thank you for the feedback :-)
fzahn - 5/18/2019 10:08:57 AM
gratd - 6/9/2019 12:23:11 PM
             Yes.
                 Huge Thanks - downloaded and worked first time.
gratd - 10/8/2019 9:41:30 AM
rk19 - 12/22/2019 2:38:56 PM
TJ - 3/3/2020 10:45:33 AM
Gourls - 1/31/2020 2:11:33 PM
arne - 3/29/2020 4:13:30 PM
TJ - 3/29/2020 9:38:37 PM
TJ - 3/30/2020 1:43:16 PM
MOIN - 7/28/2020 7:59:06 AM
