Posts: 8.3K,
Visits: 10K
Thanks for posting them, that's really helpful. I can see that the code thinks the first log is starting from takeoff because your groundspeed is under 50 knots. However I can see that if you're flying something at the slower end of the spectrum, that might be perfectly normal, so clearly our code could use some tweaking. Is that the case?
